Silverstar Headlights...Same problem?
Old Feb 18, 2005 | 10:54 AM
TegRyder33's Avatar
Default Silverstar Headlights...Same problem?
I got some of the sylvannia silverstar headlights for my birthday about a year ago (april 22nd to be exact) Just this past week though my left headlight went out . Now I know to be really careful when installing them to not touch the bulb with your figners cause the oils will burn them out quick. I guess what I am asking is, has anyone's silverstars burned out THIS fast because I remember when installing them I didn't touch the bulb what so ever and it has been less than a year since installation. I went out and bought some NOKYA extreme white ones which look really pimp...I hope they last...
Old Feb 18, 2005 | 10:57 AM
timmy8151's Avatar
Default Re: Silverstar Headlights...Same problem? (TegRyder33)
I'm assuming that you're using 9005 bulbs. If that's the case, then a year on these bulbs isnt too bad. Remember 9005 bulbs are meant for high beams, as a result, they aren't designed for daily use.
Old Feb 18, 2005 | 11:03 AM
Slain's Avatar
i've seen silverstars last from a few weeks to a year. <shrugs>
Old Feb 18, 2005 | 11:20 AM
Chaos69's Avatar
Default Re: (Slain)
I bought 2 sets of of 9005 and did the 9006 conversion on them.. Both lasted for about a year.
Old Feb 18, 2005 | 11:40 AM
RuskeR's Avatar
I didn't have one die on me until about a year and a half. I replaced one and the other died about 2 months later.
I said screw it and bought HID's.
Old Feb 18, 2005 | 12:14 PM
SonicBlueTeg's Avatar
Default Re: (RuskeR)
we have silverstars on 4 of our cars for about a year now.. strange.. cuz the 98 accord bulb on the driver's side blew out twice.. my integra lost one.. but the other daily driver accord hasnt blown a bulb since.. completely random.. i guess some are good and others arent..
i swear they have some type of warranty... anyone up to help looking for the warranty on the website that spins u in circles? i'm sure they are hiding it in the website.. http://www.sylvania.com
so far i only found a $5 rebate...
Old Feb 18, 2005 | 12:16 PM
TunerN00b's Avatar
PIAA 9005 Extreme White, 8 months so far... They're only 61 watts, instead of hte normal 9005 65 watts, so maybe they'll last longer.
Old Feb 18, 2005 | 12:25 PM
iH8RICERZ's Avatar
Default Re: Silverstar Headlights...Same problem? (TunerN00b)
lol.. i did the conversion with the silverstars...lasted just a little over one year, then one of the bulbs burnt out....then, i also said screw it and got HID's!
Old Feb 18, 2005 | 12:26 PM
scho01sux's Avatar
Default Re: Silverstar Headlights...Same problem? (iH8RICERZ)
i look at it as even if it is a year, there is a significant difference over stock, and with a 30 dollar price tag, its just not that big of a deal.
Old Feb 18, 2005 | 12:27 PM
sir boostalot's Avatar
I bought some 9005 silverstars for my low beams and my left one went out in less than two weeks. I just put my stock bulbs back in.
Old Feb 18, 2005 | 03:03 PM
Vtecfool's Avatar
Default Re: Silverstar Headlights...Same problem? (sir boostalot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TegRyder33 &raquo;</TD></TR><TR><TD CLASS="quote">I got some of the sylvannia silverstar headlights for my birthday about a year ago (april 22nd to be exact) Just this past week though my left headlight went out . Now I know to be really careful when installing them to not touch the bulb with your figners cause the oils will burn them out quick. I guess what I am asking is, has anyone's silverstars burned out THIS fast because I remember when installing them I didn't touch the bulb what so ever and it has been less than a year since installation. I went out and bought some NOKYA extreme white ones which look really pimp...I hope they last... </TD></TR></TABLE>
Did you do the 9005 conversrion? I had a feeling they weren't going to last long, about a year later they my left side went out too. The funny thing is, i couldn't even tell they were out, as i pulled in to my friends house they had to tell me. 9005 has pretty good light output for halogens.
As others stated above, the 9005s were ment to be used as high beams, which isn't used for long periods of time. This is what i think the main factor was when mine went out, which isn't bad for 1 yr
Old Feb 18, 2005 | 03:04 PM
TegRyder33's Avatar
Default Re: Silverstar Headlights...Same problem? (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">I'm assuming that you're using 9005 bulbs. If that's the case, then a year on these bulbs isnt too bad. Remember 9005 bulbs are meant for high beams, as a result, they aren't designed for daily use.</TD></TR></TABLE>
It was my 9006 left bulb (low beam) that burnt out but after reading everyones replies I guess I'm not the only one. My high beams still work fine. Oh and I did do all 4 bulbs in the conversion 9005 and 9006.
Old Feb 18, 2005 | 03:52 PM
poopguy's Avatar
I've only gotten about a year from most of the bulbs I've tried. I had Silverstars but didn't like them. They look like stock. I had Raybrigs and they lasted about a year. Cuzos looked good but didn't last. Polargs not really very white, didn't last either.
Now I have some of the "JDM Yellow" bulbs. I kinda like 'em, but they aren't very bright (like some friends I have).
trippmckee13
Apr 2, 2004 12:27 PM
Memo6453
Apr 24, 2003 06:19 PM
Chris_R
Jan 21, 2003 11:15 AM
w3accord
Apr 22, 2002 04:13 PM
puckster02
Mar 11, 2002 07:19 AM
