any one did a compression test
Old Jan 18, 2002 | 09:53 AM
WICKED2's Avatar
New User
Default any one did a compression test
any one here did a compression test on h22a engine.
do i need to take out the spark plug and remove the fuse for the relay.
need help u guys
Old Jan 18, 2002 | 12:19 PM
hybridreams's Avatar
Default Re: any one did a compression test (WICKEDII)
You just need to take out the spark plugs.
Old Jan 18, 2002 | 12:28 PM
BluLuder's Avatar
Default Re: any one did a compression test (hybridreams)
you need to do more than that or your going to make a mess.
I watched it done on mine, but it looks as if they took the fuse out for the gas so that when they
hit the throttle it wouldnt spray gas.
Old Jan 18, 2002 | 01:10 PM
WICKED2's Avatar
New User
Default Re: any one did a compression test (BluLuder)
what fuse and where?
Old Jan 18, 2002 | 01:50 PM
Mikey3000's Avatar
remove the fuse for the fuel pump relay. i think it's under the dash. it'll say on the back of the fuse box cover.
Old Jan 18, 2002 | 07:26 PM
migo's Avatar
New User
Just disconnect the coil-Trust me your car won't start and crank it for 4-5 seconds... You don't have to hold the throttle open
Old Jan 19, 2002 | 11:20 AM
4bidden's Avatar
Default Re: any one did a compression test (D.specs)
around how much does a compression checker cost?
Old Jan 19, 2002 | 12:17 PM
WICKED2's Avatar
New User
Default Re: any one did a compression test (4bidden)
ok
i did the compression i took out the ecu fuse and unplug the distributor. i crank the engine 5 times the first resolt came out
1 255
2 250
3 250
4 250
dis means all my cyclinder are ok except for my 1 its burning hot
Old Jan 20, 2002 | 11:03 AM
migo's Avatar
New User
Thats good, your holding good compression
Old Jan 20, 2002 | 12:13 PM
4bidden's Avatar
is the compression checker expensive? where can you pick one up at? id like to check mine.
Old Jan 21, 2002 | 12:43 AM
sagaprelude's Avatar
mines bad
1 150
2 couldnt seal, sparkplug ate some thread so it couldnt seal
3 180
4 180
damn whats does this mean?!?!?
H2b-eghatch
Nov 8, 2016 04:44 PM
j-rome
Oct 25, 2007 11:27 PM
yh23
Aug 14, 2005 04:21 PM
17GSR17
Jun 19, 2004 08:14 AM
dutchman5
Mar 9, 2003 07:16 PM
