ABS = Noise?
Old Feb 18, 2005 | 09:03 AM
seifer's Avatar
Default ABS = Noise?
Whats that big noise when ABS brakes take on? Im not sure if its normal but its as if a mini motor engages (sorry Im not even sure how ABS work). "brrrrrrrr" is it normal?
Also, is it a good idea to remove my ABS? I just find it annoying... How do you toggle that on/off or if necessary, how do you remove this feature?
Old Feb 18, 2005 | 10:02 AM
BUJonathan's Avatar
Default Re: ABS = Noise? (fukushuu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fukushuu &raquo;</TD></TR><TR><TD CLASS="quote">Whats that big noise when ABS brakes take on? Im not sure if its normal but its as if a mini motor engages (sorry Im not even sure how ABS work). "brrrrrrrr" is it normal?
Also, is it a good idea to remove my ABS? I just find it annoying... How do you toggle that on/off or if necessary, how do you remove this feature?</TD></TR></TABLE>
You should get a pusling noise like a pump cycling, and feel the pedal pulsating under your foot.
Old Feb 18, 2005 | 10:05 AM
seifer's Avatar
Default Re: ABS = Noise? (BUJonathan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUJonathan &raquo;</TD></TR><TR><TD CLASS="quote">
You should get a pusling noise like a pump cycling, and feel the pedal pulsating under your foot.</TD></TR></TABLE>
Thanks. Glad to know its normal for the noise, any idea on how to disable the ABS, or even toggle it?
Old Feb 18, 2005 | 10:32 AM
GSR_Jamee's Avatar
ive got a noise comin from my ABS too. it goes ''eeeeeehhhhhhhhhhhhhh'' for a few mins, and then goes away. anyone know what that is?
Old Feb 18, 2005 | 10:46 AM
seifer's Avatar
Default Re: ABS = Noise? (GSR_Jamee)
nice!!... a chick with a GSR!
Old Feb 18, 2005 | 11:07 AM
LsHoney84's Avatar
I believe thats the abs pump repressuring.(I think)
Also if you slam on your brakes, you should feel a vibration and hear a buzz.
I tried it on my suv and you can hear the abs.
Old Feb 18, 2005 | 11:11 AM
seifer's Avatar
Default Re: ABS = Noise? (LsHoney84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsHoney84 &raquo;</TD></TR><TR><TD CLASS="quote">I believe thats the abs pump repressuring.(I think)
I tried it on my suv and you can hear the abs.</TD></TR></TABLE>
Ok thanks, happy to hear its normal.
Old Feb 18, 2005 | 10:31 PM
Bay_707's Avatar
you can take out the abs fuse module its about the size of a boxed chocolate candy you get from see's but a little bigger... its right behind the abs module in a box that looks like it has fuses in it... i believe it says so on the box also... If your abs module is leaking like mine did it will make those noises.
Old Feb 18, 2005 | 11:58 PM
virusiidx's Avatar
dont take out the abs, its a security option that might come in handy one day when you slam on your brakes, it'll keep you from swirving and spinning out.
Old Feb 19, 2005 | 02:08 AM
WhiteGSR95's Avatar
high pressure leak, i think that u gatta replace the abs unit
Old Feb 19, 2005 | 06:02 AM
GrayT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fukushuu &raquo;</TD></TR><TR><TD CLASS="quote">nice!!... a chick with a GSR! </TD></TR></TABLE>
Who gives a ****.
I would also like to know exactly what causes the noise from the ABS.
eliasromero
Mar 16, 2007 04:57 PM
nm_Civic_DrVr
Honda Civic (2006 - 2015)
Dec 27, 2006 09:51 AM
kbxer22
Honda Civic (2001 - 2005)
Dec 24, 2006 07:29 PM
Havokgsr
Dec 15, 2002 01:11 AM
Warren
May 18, 2002 09:37 PM
