Quick Q, my frined just got his S2K and .........
........ His headlights are "off."
Is there an easy way adjust the beam level/orientation of the headlight? Or do you have to take it to the "stealer" to get it done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bs-inc.s2k »</TD></TR><TR><TD CLASS="quote">mine aren't even either. like nishant said my left headlight is a little lower</TD></TR></TABLE>
its supposed to be that way. its law so you don't blind on coming traffic
but that doesn't mean you can raise both a lil like me
thats how they are supposed to be....the drivers side is lower then the passenger side.... just like nishant said... it's like that to not blind on comming traffic...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi »</TD></TR><TR><TD CLASS="quote">I had my lights taken out before. My passenger side is lower. We can adjust them at our mini mod day. </TD></TR></TABLE>
i don't think he will be coming to our mini mod day, he's in kansas
My friend said it is his passenger one as well ........ not the driver.
The car was in an accident more than likely from the previous owner, so that is what we suspect on it. They probably replaced the front or something and didn't adjust the lights correctly.
So what exactly is involved in adjusting them? I've done it easily on other cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">i don't think he will be coming to our mini mod day, he's in kansas
I meant my lights.
</TD></TR></TABLE>I meant my lights.
I meant my lights.
we're adjusting mine too...need to raise mine
I meant my lights.
</TD></TR></TABLE>we're adjusting mine too...need to raise mine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi »</TD></TR><TR><TD CLASS="quote">I saw instructions how somewhere. Something like park 25ft away from wall and the light beam should be 2ft high on the wall. I think not sure.</TD></TR></TABLE>
i have the service manual, we can look it up
I know "how" to do it .... like I said, I've done it on other cars ........
Just don't know what is involved in getting to the adjustment screws/settings. That's why I was trying to see if anyone here has done it and what they did to do it.
instructions as per service manual:
1. clean the outer lens so that you can see the center of the headlights
2. park the vehicle 25ft away from a wall or a screen
3. open the hood
4. turn the low beams on
5. meausre from ground to center of headlight. the low beam reflection on the wall should be 2.1 inches below this height
6. if necessary, adjust headlights vertically by turning the vertical adjuster (look near the bulb for this). from the pictures, it looks like they use a philips head screwdriver
3. open the hood
