need help having problems with my motor !!
Old Feb 17, 2005 | 10:26 PM
Battle Cat's Avatar
B A N N E D
Default need help having problems with my motor !!
i have oil in my car but my oil ligth comes on ?? And it also turnes off when i'm at idle. Does anyone know what the hell is going on.
Old Feb 18, 2005 | 01:39 AM
WhiteGSR95's Avatar
check ure oil pressure
Old Feb 18, 2005 | 06:15 AM
Battle Cat's Avatar
B A N N E D
Default Re: (WhiteGSR95)
kind it be that i have tomuch oil to ??
Old Feb 18, 2005 | 06:16 AM
Battle Cat's Avatar
B A N N E D
How do i check my oil pressure ??
Old Feb 18, 2005 | 06:50 AM
seifer's Avatar
Default Re: (Battle Cat)
what about the oil sensor itself?
Old Feb 18, 2005 | 07:36 AM
Battle Cat's Avatar
B A N N E D
Default Re: (fukushuu)
my motor has like 135,000 miles you think that could be it ??
Old Feb 18, 2005 | 07:40 AM
RuskeR's Avatar
How much oil did you add when you changed it?
Old Feb 18, 2005 | 08:07 AM
seifer's Avatar
Honestly Im not sure... guess it could just be badluck (if it is the sensor), it's just something more to consider if you don't find the source of your problem right off the bat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Battle Cat &raquo;</TD></TR><TR><TD CLASS="quote">my motor has like 135,000 miles you think that could be it ??
Old Feb 18, 2005 | 08:18 AM
greaseball's Avatar
your oil light is not warning you that your oil is low, it is warning you that you have low oil pressure. it could be the sensor or it could be the fact that you are in fact losing oil pressure. do a leakdown/compression test and double check your oil.
what kind of car/motor??? if your oil light is coming on, v-tec should not work. if, of course, you have a v-tec engine.
Old Feb 18, 2005 | 09:42 AM
VTEC Visions's Avatar
Default Re: need help having problems with my motor !! (Battle Cat)
There is another guy on this forum having the same problem. Check your oil pressure asap at a shop.
Old Feb 18, 2005 | 12:47 PM
Battle Cat's Avatar
B A N N E D
Default Re: need help having problems with my motor !! (VTEC Visions)
cool guys thanks alot
Old Feb 18, 2005 | 12:53 PM
Battle Cat's Avatar
B A N N E D
is it easy to instill a oil pump or should i just take it to a shop ?? i put cams in my car, is it as hard as that ???
Old Feb 18, 2005 | 01:02 PM
dick_213's Avatar
if you put cams in your car i dont see why you wouldnt be able to put in an oil pump. just remember to prime the whole system before you start the car. and if ur oil light keeps coming on try not to run ur car for long .... or there go the bearings.
MyUsernameName
Jun 15, 2017 02:06 PM
liitezout
Jul 6, 2005 12:03 AM
RemerLex11
May 15, 2005 02:35 PM
fastludeh22
Sep 10, 2003 12:12 PM
bey
May 11, 2003 08:36 PM
