Heater core.. yes i know search hear me out
illl be sitting there and its luke warm and ill rev it to like 2k and it gets hotter automatically so what im thinking is that when it revs it makes the water pump push more coolant through the partially clogged areas of the core
so im thinking thats the problem
i also have a problem.. my car doesnt stay warm itll warm up fine but if i drive around it will go back down to almost C on the temp guage.. so i put a pice of cardboard on the rad and it made it a bit better...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 »</TD></TR><TR><TD CLASS="quote">illl be sitting there and its luke warm and ill rev it to like 2k and it gets hotter automatically so what im thinking is that when it revs it makes the water pump push more coolant through the partially clogged areas of the core.</TD></TR></TABLE>
could be that, bad pump, or no thermostat or it is staying open
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 »</TD></TR><TR><TD CLASS="quote">my car doesnt stay warm itll warm up fine but if i drive around it will go back down to almost C on the temp guage.. so i put a pice of cardboard on the rad and it made it a bit better...</TD></TR></TABLE>
sounds like a thermostat problem (staying open or non existant)
one from autozone.. but that was in the dseries.... my thermo works fine in this one ive waited and felt the upper andlower hoses and bottom would stay cold while top was hot.. then after a while the bottom would start to warm
yes sir.. its very wierd... i covered my rad with a few pieces of cardboard and it helped a little bit with the engine tempurature but the heat isnt hot still.... when i rev it it will get kinda hot but no other times... so i am guessing its time for a timing belt, water pump ,and a new heater core
turbo-crx
May 14, 2008 07:04 PM
richboi
Mar 25, 2006 04:41 PM
jedubz
May 6, 2004 08:43 PM
