fuel pump not clicking on with h22a in my civic
Old Feb 17, 2005 | 07:27 PM
kholmes's Avatar
Default fuel pump not clicking on with h22a in my civic
Alright, just dropped a jdm h22a in my 98 hb and when the ignition is turned on the Walbro fuel pump doesnt power up. Theres no power to it at all. Would this be the ecu? The ecu is a p28 with a conv harness obd2-1. We jumped the pump to another 12v and it came on.
Old Feb 17, 2005 | 07:49 PM
Turbogixxer's Avatar
Default Re: fuel pump not clicking on with h22a in my civic (kholmes)
Your CEL turn off after 2 seconds after turning hte key to the "ON' position?
CEL = Check Engine Light
Old Feb 17, 2005 | 07:52 PM
kholmes's Avatar
Default Re: fuel pump not clicking on with h22a in my civic (turbogixxer)
The CEL light stays on solid.
Old Feb 17, 2005 | 07:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kholmes &raquo;</TD></TR><TR><TD CLASS="quote">The CEL light stays on solid.</TD></TR></TABLE>
Check the main relay. If the P28 is chipped, check the chip (bad burn/bin) and the soldering.
Old Feb 18, 2005 | 03:03 PM
kholmes's Avatar
I dont think its chipped and Ive checked all fuses in and out. My first thought is that I cut into the fuel pump wire when cutting the holes for the shifter but cant tell if the wire runs through the middle of the car or to the side?
Old Feb 18, 2005 | 03:46 PM
v4lu3s's Avatar
RTFM
no wires run through the middle of the car that have anything to do with the fuel system.
Old Feb 18, 2005 | 04:11 PM
0vrbst_t66's Avatar
when you turn your key to the on position your cel light should come on then shut off within a few seconds.if it stays on you have a problem somewhere.jump a wire on the cel service plug and tell us what trouble code your getting(if you dont know where this service plug is go buy a haynes manual it will help you a ton).
Old Feb 18, 2005 | 05:47 PM
kholmes's Avatar
Default Re: fuel pump not clicking on with h22a in my civic (0vrbst_t66)
Yeah, the light stays on solid. I gess that means 0 for pcm right?
Old Feb 18, 2005 | 06:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kholmes &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, the light stays on solid. I gess that means 0 for pcm right?
Not exactly. If the ECU is not getting power, the CEL light will stay on. If the ECU is bad(most of the time), the CEL will stay on. You have to figure out why the CEL is stay on. Check the ECU fuse too (15a on the fuse box).
Old Feb 18, 2005 | 06:12 PM
kholmes's Avatar
All the fuses under the dash and under the hood have been pulled and checked.
The ecu looks rough and the conv harness looks rougher.
Old Feb 18, 2005 | 06:23 PM
kholmes's Avatar
A guy I know said the ecu has nothing to do with the fuel pump, is this true?
Old Feb 18, 2005 | 09:18 PM
kholmes's Avatar
ok, issue solved. It was a wire on the conv. harness. I pulled the harness off the ecu and a wire came out so I soldered it back and the pump comes on now. And the ecu is chipped, I looked in it and theres JUN writen in there. Anyways, thanx for the help, now I need to see why my cluster isnt lighting up and why my battery is dying so quickly.
Old Feb 19, 2005 | 03:20 PM
hondaZvic's Avatar
glad u got that fixed..
any time u have problems from now on, always check ur conversion harness. there have been so many people (myself included) that have had problems with them.. (wires coming off and throwing codes or keeping ur car from running).
aftermarket conersion harnesses i know some are good.. but i havent seen any.
Old Feb 19, 2005 | 04:49 PM
kholmes's Avatar
Default Re: fuel pump not clicking on with h22a in my civic (hondaZvic)
Thats cool. The motor runs but backfires sometimes and the cel code is still showing pcm??? Im gonna change the wires and rotor/cap and see if that helps.
JRciv
Engine Management and Tuning
45
Feb 16, 2023 01:27 PM
the_insider
Feb 29, 2016 12:06 PM
vtakej
12
Jul 28, 2010 02:15 PM
forcefed22
Sep 18, 2008 08:18 PM
Dr Pooface
Sep 28, 2004 06:09 PM
