ls vtec + b20 vtec owners..........gas?
what kind of gas mileage are you getting out of your ls vtec or b20 vtec engines? i'm planning to do a ls but maybe a b20 swap, just wondering what i don't have to look forward to..............also, what is your setup with your mileage please!!
-searched but kinda random, i want to know only these 2 engines and mostly the ls
thanks!
thanks!
Getting 24 miles to a gallon and I mash the gas frequently..LS bottom end is mildly built and B16 head has upgraded valve springs and retainers...just make sure you get a tough/short brass fitting to run the vtec line...my cheap one broke..it was a bitch to fix
on my teg on a full tank of gas, i am about 340 miles out ot it. its a 91 with a 160,000 on the bottom end. no bull **** either. im suprised i get good gas milage as much as beat the **** out of it. my gas milage didnt change at all. oh and its an ls/vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRC »</TD></TR><TR><TD CLASS="quote">on my teg on a full tank of gas, i am about 340 miles out ot it. its a 91 with a 160,000 on the bottom end. no bull **** either. im suprised i get good gas milage as much as beat the **** out of it. my gas milage didnt change at all. oh and its an ls/vtec.</TD></TR></TABLE> LS tranny?
Yes 30mpg or so going 80mph @4000rpm...the Ls tranny is good for my daily beater.
[QUOTE=tthomass]what kind of gas mileage are you getting out of your ls vtec or b20 vtec engines? i'm planning to do a ls but maybe a b20 swap, just wondering what i don't have to look forward to..............also, what is your setup with your mileage please!!
As for my setup it has stock Ls rods, new Honda bearings, bolts, .25 type R pistons w/rings, hot tanked, decked, bored, honed, micro-polished crank, new gaskets, B16A head with titanium valve springs and retainers, Type R intake mani, stock ECU (chipped one took a ****), Ls timing belt and new LS water pump, GSR oil pump. 170whp I wish I turbo built the bottom end instead of going with a mild build, something for you to consider.
i run a 99 gsr tranny and a i get like 240 mpg my set up like your but a little different here it is
block
99b18b
ac blockguard
arp mainstuds
golden eagle blockgirdle
arp headstuds
ge oil adapter
acl bearings
itr oil pump
gsr gmb waterpump
balanced crank
shotpeened rods
p73aoo pistons
new oil pan gasket
flp baffled oil pan
obx pulleys
itr crank pulley
drivetrain
gsr tranny
ls 5th gear
itr lsd
act stge 3 6 puck ceramic
comp clutch 9.5 lb flywheel
flp clutch line
compression 11:9:1
head b16a2
rev valvetrain
rev flat valves
port matching on tb & manifold
blox hi lift cams
i put the 64mm back on
blox manifold
h22 vtec 290 injectors flowed/cleaned
190 fuel pump
new valve gasket
new headgasket
new orings
tuning
p28 with uberdata ge cam gears
block
99b18b
ac blockguard
arp mainstuds
arp headstuds
ge oil adapter
acl bearings
itr oil pump
gsr gmb waterpump
balanced crank
shotpeened rods
p73aoo pistons
new oil pan gasket
flp baffled oil pan
obx pulleys
itr crank pulley
drivetrain
gsr tranny
ls 5th gear
itr lsd
flp clutch line
compression 11:9:1
head b16a2
rev valvetrain
rev flat valves
blox hi lift cams
blox manifold
190 fuel pump
new valve gasket
new headgasket
new orings
tuning
95_hatch
May 5, 2004 04:49 PM
