Power Wire Gauge Vs. Amp Output Power
Old Jan 18, 2002 | 06:00 AM
BlackAckeR's Avatar
Default Power Wire Gauge Vs. Amp Output Power
I know the basics of electricity, but not how to calculate this... Say I'm adding an amp in my car that puts out 60 watts into 2 channels; what gauge power wires do I need? I know Wattage = Amps * Volts, but I don't know what current the amp is drawing from the battery. I don't want a thicker gauge than I need, and I'm guessing I don't need 10 gauge or lower for these specs!?...
Can anyone tell me how to calculate or better estimate what I need?
tia.
Old Jan 18, 2002 | 11:08 AM
ck279's Avatar
Default Re: Power Wire Gauge Vs. Amp Output Power (BlackAckeR)
Yeah, there is an equation for calculating it. For what you descibed though, 10 AWh will be fine. If you think you might run a larger amp, or more amps in the future you should step up to 8 AWG or larger.
Old Jan 18, 2002 | 05:39 PM
thefordmccord's Avatar
just go ahead and run some 2 gauge welder cable... haha
Old Jan 19, 2002 | 05:35 AM
redblues's Avatar
New User
It depends on how long the wire will be and how much you plan on expanding in the future.
My general estimates are: (for 15-20 feet of wire, from battery to trunk mounted amp)
0/2 gauge, over 1000W
4 gauge, over 600W
8 gauge, over 200W
10 gauge for everything else.
Better safe than sorry, you could run 12 gauge at the risk of the wires overheating.
Old Jan 19, 2002 | 02:19 PM
GSteg's Avatar
Default Re: Power Wire Gauge Vs. Amp Output Power (redblues)
yea...don't go with 12 guage. i ran a 12 guage wire for my lightning audio amp (50x2 watts RMS) and it shuts off when a bass note hits. its not delivering enough power through the 12 guage. so i switched to 8 gauge and it made a big difference. i originally used my 12 gauge for my 20x2 watt amp (pretty good for only 30 bucks. ) the BIGGER..the BETTER. its never wrong to go with a bigger wire.. of course don't get a 0/1 guage for a 100x1 amp...it wouldn't be wrong..just stupid. hehe
Old Jan 19, 2002 | 06:03 PM
ooostenb's Avatar
Default forget 10awg
unless your amp is like 50 watts (peak), i wouldnt use anything smaller than 8awg. it carrys a lot better than 10 and it is a lot safer.
Old Jan 19, 2002 | 08:27 PM
CanadaCivicSIR's Avatar
New User
Default Re: forget 10awg (ooostenb)
If you are planning on doing a system in your car eventually, then you will have to upgrade your wires from 10 or 8 awg to 4 awg or 1/0 guage. So just to be safe and save some money in the long run, I would run 4 awg from the start.
Or you could, later on, if you ran 8 awg run another 8 awg right beside it.
But the general rule of thumb is no matter what amp run at least 8 Awg wire.
As per calculations:
60 x 2 equals 120 watts
120watts/12Volts equals 10 Amps
However that amp would draw 10 amps if 100% efficient, no amplifier is 100% efficient. Most amps are 1/3 to 1/2 efficent, so the calculations don't work like they are suppose to for this.
[Modified by CanadaCivicSIR, 9:32 PM 1/19/2002]
tempsohc
Audio / Security / Video
Jul 31, 2013 09:30 PM
dohcvtak
May 21, 2009 09:11 PM
sirg-vtec
Jan 5, 2008 05:12 PM
tinkertime
Jun 15, 2006 09:54 PM
jwrcivicdx
May 1, 2003 10:57 PM
