Another LS/V question...click me!!
ok so i traded my turbo kit for a full ls/v set up..
b18a1 block
gsr crank with rods
b16 pistons
89 b16 vtec head mild port and polish.
got all new gaskets and washers for the motor... but ive heard ls/v give a lot of oil leak problems wat can i do to avoid this??
b18a1 block
gsr crank with rods
b16 pistons
i hate to break it to you but you pretty much have the making for a really shitty gsr motor.
putting a gsr crank in an ls block is the exact opposite of the whole concept behind lsvtec.
you see the ls block has a larger stroke which is where you get the extra power over the gsr stroke. so when you put the gsr crank in a ls block, it has the same stroke as a gsr, just in a shittier block....
hope this make sense.
as far as the lsvtec "having a lot of problems" wheater it be oil or anything else, it all has to do with how the motor was built. build it well and it will preform well.
Modified by envision2teg at 4:10 PM 2/17/2005
[QUOTE=envision2teg]i hate to break it to you but you pretty much have the making for a really shitty gsr motor.
QUOTE]
makes sence got ya
QUOTE]
makes sence got ya
he is right, lsvtec done rite will not leak oil, i dont know where people get leaking oil from? unless they didnt do it rite, i built a few ls/vtec they all ran fine with me, just make sure u get the vtec oil passage on the head welded or plug and the rite fittin for the oil feed line then u should be fine,
as far as the tapping goes it already pre tapped...and wat would i want to DO and NOT DO to aviod leaks. im new at this whole lsv thing, im more a of boost guy..but im tryin something new. so help me out pplz
Modified by hitvtecgetloud09 at 4:25 PM 2/17/2005
An LS/Vtec shouldnt have anymore leaks than a normal Vtec motor.
Only thing to really leak is the Vtec plug or oil line. Just make sure it is all tight.
i would get arp rod bolts and a vtec oil pump and water pump and u will have to get a gs-r timing belt, sumone people might think u dont need to swap out oil and water pump but i do it just to be on the safe side. rod bolts is a must i say if u want to rev high
definitely go for it. the only difference would be that you have the shorter stroke and .2 points less for compression. i am running this setup cause i had an ls block and picked up some gsr internals for really cheap. i threw some arp rod bolts on the gsr rods and some p30 pistons so it gave a comp around 11.5 with the omnipower flat faced valves. my setup put down 174whp and 130 ft lbs of torque just with 30 mins of tuning and i still didn't touch the cam gears. i only played with the vafc and the a/f is still pretty sloppy. ran 14.1 at the track with a 2.3 60 ft. i can definitely can get into the 13's with this setup in a heavy *** ex coupe
Modified by vtec94civic at 4:27 AM 2/18/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec94civic »</TD></TR><TR><TD CLASS="quote">definitely go for it. the only difference would be that you have the shorter stroke and .2 points less for compression. i am running this setup cause i had an ls block and picked up some gsr internals for really cheap. i threw some arp rod bolts on the gsr rods and some p30 pistons so it gave a comp around 11.5 with the omnipower flat faced valves. my setup put down 174whp and 130 ft lbs of torque just with 30 mins of tuning and i still didn't touch the cam gears. i only played with the vafc and the a/f is still pretty sloppy. ran 14.1 at the track with a 2.3 60 ft. i can definitely can get into the 13's with this setup in a heavy *** ex coupe
Modified by vtec94civic at 4:27 AM 2/18/2005</TD></TR></TABLE>
dam all this makes me wana go work on it now...ima be doin a lil more motor work then uve done..ima go with the hondata ecu as well. ill post progress
