2000 LS motor Losing 1 qt every 300 miles
Old Feb 17, 2005 | 08:58 AM
peel17's Avatar
Default 2000 LS motor Losing 1 qt every 300 miles
2000 LS motor Losing 1 qt every 300 miles..
Here's what i've done.
Compression check was good.
Leak Down Test came up good
Checked underneath the car - Couple of drips from the washer.
Checked around the valve cover - need to get a new oil cap. Leaking out. Also leaking from the tube rings.
Checked the around the head cylinder firewall. no leaks. around the engine bay. No leaks.
Any tips or info on this issue????? BTW: I did a swap.. 2000 LS motor into DA
Modified by peel17 at 10:46 AM 2/17/2005
Old Feb 17, 2005 | 10:40 AM
xTravBx's Avatar
Default Re: 2000 LS motor Losing 1 qt every 300 miles (peel17)
You would notice that much oil sitting in a puddle under your car.
Fix those minor leaks and see what happens.
Do you blow smoke out your exhaust? If so, what color?
Pull your spark plugs and see if they're fouled out from burning oil.
Old Feb 17, 2005 | 10:42 AM
peel17's Avatar
ohh forgot to mention.. no smoke
checked PCV vales and there good. Spark plugs are good to.
Old Feb 17, 2005 | 01:19 PM
peel17's Avatar
bump..
Old Feb 17, 2005 | 01:33 PM
drift2004's Avatar
ah no wonder, is this the pcv valve the reason i lose oil, because i just have it dumping to the floor, right?
Old Feb 17, 2005 | 01:42 PM
rough_draft's Avatar
Default Re: 2000 LS motor Losing 1 qt every 300 miles (drift2004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2004 &raquo;</TD></TR><TR><TD CLASS="quote">ah no wonder, is this the pcv valve the reason i lose oil, because i just have it dumping to the floor, right?</TD></TR></TABLE>
huh?
Old Feb 17, 2005 | 03:36 PM
drift2004's Avatar
Default Re: 2000 LS motor Losing 1 qt every 300 miles (Lmaonade)
no cuz i been losing oil 2 since it is not being put back into the engine oil goes to the floor
alchemyst6
18
Jul 21, 2011 10:08 AM
memphosfinest
Aug 30, 2005 07:27 PM
ekcivicphx
Feb 2, 2005 02:21 PM
Honda only
Honda S2000
22
Sep 5, 2004 06:34 PM
arcboy
Oct 15, 2001 05:13 PM
