Valve sticking or bad stem seal, would you still boost??
OK guys I have 99% of everything and want to get ready to install my stuff. I have one problem though. I think one of my exhuast valves is sticking at high rpms or maybe a valve stem seal is going bad becuase i burn oil at high rpms (only visible smoke at high rpms). I did a comp test and got 210 across the board.
So would you all still boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">I would fix that before boosting. Its only gonna get worse with boost
Is the block stock? In my car, I had oil issues when I built my motor because I got the ring gaps inline on #1. Fixed and everything is fine now...
Yes the block is stock.
I dont burn a whole lot of oil. maybe in 2 weeks ill have to put in <1/4 of a quart. That is with me driving it hard and going about 30miles a day.
boost it, dooo it, you knwo you want to.
but i would do a leakdown test first and foremost, then look at your options. if its a valve, then might as well upgrade teh valvetrain, or just look for a head in a junkyard or something. the joys of having a d-series.
Oil in the combustion chamber is very bad since it has an effective octane rating of 0. Unless you like detonation, don't run your engine in this state.
