JDM D15B tranny with LSD bolt on to D16Y7 block....
Old Feb 16, 2005 | 09:36 PM
turbo95eg6's Avatar
Default JDM D15B tranny with LSD bolt on to D16Y7 block....
Without any problems what so ever...? No swapping or interchanging gears required...?
thanks
Old Feb 16, 2005 | 09:55 PM
BlueIntegraBoy's Avatar
Default Re: JDM D15B tranny with LSD bolt on to D16Y7 block.... (turbo95eg6)
Yes, it should bolt up.
Old Feb 16, 2005 | 09:58 PM
Timmay's Avatar
Default Re: JDM D15B tranny with LSD bolt on to D16Y7 block.... (BlueIntegraBoy)
yes all 92-00 civics sohc share the same tranny casings
go for ****!!!
Old Feb 16, 2005 | 10:04 PM
turbo95eg6's Avatar
Default Re: JDM D15B tranny with LSD bolt on to D16Y7 block.... (Timmay)
OK....double checking...so a JDM D15B S20 tranny WILL work with my D16Y7 bottom end correct...? lol
Old Feb 16, 2005 | 10:18 PM
Timmay's Avatar
Old Feb 16, 2005 | 10:25 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
yulp, any D series tranny will mate.. even pre OBD.. i think 88-00 will, only problem, pre OBD EF chassis was cable trannsmission, all 92+ are hydrolic, but any SOHC tranny will bolt up.
i have a EK EX tranny in my EG.
Old Mar 15, 2005 | 12:14 PM
bmheck5184's Avatar
Default Re: JDM D15B tranny with LSD bolt on to D16Y7 block.... (Built B16A)
anyone know if a JDM CVT tranny will bolt up to a usdm HX motor? The CVT tranny in mine is screwed and I found a good deal on a JDM unit.
Would any wiring/ecu changing be necessary?
schreff
Aug 31, 2007 02:54 PM
logikalfury
10
May 18, 2005 11:13 PM
jdjustme
May 12, 2005 05:50 PM
GOTNOS
Feb 9, 2004 08:44 AM
eg6ajk
Jan 2, 2003 11:14 AM
