SOHC ZC VTEC info needed plz, asap!
Old Feb 16, 2005 | 04:42 PM
Tad's Avatar
Tad
Default SOHC ZC VTEC info needed plz, asap!
Hi,
so i'm about to purchase another sohc vtec motor.
I have a chance to get a ZC sohc vtec, which i've been told is rated at 140hp,
and is a 1.6L
my last motor was a d15b vtec, which I can also get,
its 130hp (actually i think both ratings are ps).
NOW you may wonder why I would even consider the 1.5 over the 1.6,
well the d15b actually has a really nice rod/stroke ratio, so it revs very freely,
I run a 8k rpm rev limit, so I don't want any problems reving that high(i wont go higher on the stock head/block though).
Also parts wise, I know didly about the ZC,
the longblock will be bare most likely, so i'll need to get things like water pump, thermo, timing belt, etc...
Can you guys plz give me info on the SOHC ZC VTEC 1.6L ?
I'll need to know things like what kind of head it has,
what kind of block, r/s ratio, etc etc.
ALSO from what I know, the d15b has a really great cam in it,
how is the cam in the ZC ?
would swapping the d15b cam into the zc be a good mod? Cuz I do have a busted d15b lying around now..
Thanks in advance.
Old Feb 22, 2005 | 11:20 AM
dubzxallxstar's Avatar
Default Re: SOHC ZC VTEC info needed plz, asap! (Tad)
sup TAD i have a sohc zc also.. i blew my other motor the d16z6... i been drivin around the zc almost 9 month now it runs pretty good...im not sure about the ratio or anything like that... but i like... its a single head.. but damn it runs pretty strong...
Old Feb 22, 2005 | 12:03 PM
menappi's Avatar
zcs are non vtec buddy
Old Feb 22, 2005 | 12:07 PM
POE's Avatar
POE
the cam in the jdm d15b is like the comp cam 59100 i have heard... they are very similar..
Old Feb 22, 2005 | 12:10 PM
DelSolSi93's Avatar
Default Re: (menappi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menappi &raquo;</TD></TR><TR><TD CLASS="quote">zcs are non vtec buddy</TD></TR></TABLE>
then WTF is this? http://cgi.ebay.com/ebaymotors...=WDVW
Old Feb 22, 2005 | 12:11 PM
egOt's Avatar
Umm...you might wanna redo your research there buddy.
Old Feb 22, 2005 | 12:14 PM
Discosteak's Avatar
would you like me to take a picture of my engine?
Old Feb 22, 2005 | 12:16 PM
Discosteak's Avatar
Default Re: (BADEG4)
you can use all d16z6 parts as far as water pump t-belt etc. my long block came with evrything but the alternator and belt though. the cam in the zc feels larger than my d15b it pulls very hard in vtec all the way to rev limit. what happened to your d15b?
Old Feb 22, 2005 | 05:55 PM
Tad's Avatar
Tad
well I ended up not being able to get the sohc vtec zc
and yes it does exist.
there are THREE zc's.
dohc (nonvtec)
sohc (nonvtec)
sohc-VTEC
picked up a jdm d15b,
detonated my old one
Old Feb 23, 2005 | 05:46 AM
i think your wrong on that i have a zc thats has vtec.....the only different between the d16z6 and the zc is black valve cover... and the stamp on the block.....
Old Feb 23, 2005 | 07:42 AM
Pioneer162's Avatar
search owns just about everyone in this thread. THERE IS ALREADY A THREAD ABOUT THIS!
https://honda-tech.com/zerothread?id=1087149
I was the one who started it. We've found that the only difference between a D16Z6 and a JDM SOHC ZC (yes they made one VTEC) is the the ZC has a more aggressive camshaft. Everything else is identical, including timing belt, water pump, etc, etc, etc........
Old Feb 23, 2005 | 07:52 AM
Default Re: SOHC ZC VTEC info needed plz, asap! (Pioneer162)
this is outta the question... but do u know any good setup for this motor..... to get the most power out of it ...doing all motor..???any advice..
Old Feb 23, 2005 | 08:46 AM
Pioneer162's Avatar
Default Re: SOHC ZC VTEC info needed plz, asap! (dubzxallxstar)
again search owns you.
https://honda-tech.com/zerosearch
Old Feb 23, 2005 | 11:00 AM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pioneer162 &raquo;</TD></TR><TR><TD CLASS="quote">search owns just about everyone in this thread. THERE IS ALREADY A THREAD ABOUT THIS!
I was the one who started it. We've found that the only difference between a D16Z6 and a JDM SOHC ZC (yes they made one VTEC) is the the ZC has a more aggressive camshaft. Everything else is identical, including timing belt, water pump, etc, etc, etc........</TD></TR></TABLE>
thanks.. but how do you expect to find that with a search when you cannot search for "zc" ??
Old Feb 23, 2005 | 11:26 AM
Pioneer162's Avatar
Your search for SOHC ZC returned 4 results.
Your search for SOHC vs D16z6 returned 28 results.
Old Feb 23, 2005 | 01:04 PM
nxstrikerxn's Avatar
hey i was wondering how does ur d15b rev at 8k mines only rev at 7.5 n i have p28 ecu n ex cluster. What is ur setup
Old Feb 23, 2005 | 01:08 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pioneer162 &raquo;</TD></TR><TR><TD CLASS="quote">Your search for SOHC ZC returned 4 results.
Your search for SOHC vs D16z6 returned 28 results.</TD></TR></TABLE>
sohc zc turns up 120 results for SOHC and warns that the word "zc" was not searched for because the search engine can only search for 3letters or more
and that was recent topics.. archived = 900
about the revlimit, I havea chiipped/socketed ecu.
Old Feb 23, 2005 | 01:09 PM
Default Re: SOHC ZC VTEC info needed plz, asap! (nxstrikerxn)
if u want to rev over 8k try using a pr3 ecu for a b16...... it revs like 9k from what i remember....
Old Feb 23, 2005 | 01:18 PM
Tad's Avatar
Tad
8k is about as high as you can go safely on a sohc.
Old Feb 23, 2005 | 01:21 PM
yeah i learn the hard way...i blew my motor racing a celica gts.... now i got the sohc zc vtec...
Old Feb 23, 2005 | 01:30 PM
JoKarma's Avatar
Is the zc vtec pretty impressive?
Old Feb 23, 2005 | 01:35 PM
Tad's Avatar
Tad
if it's exactly like the z6, except for the cam,
then i'm happy with my d15b.
I like the crazy smooth revving of it.
wouldn't mind that down low torque of the 1.6 though.. if only there was a 1.6 sohc motor with the d15b's rod/stroke ratio..
Old Feb 23, 2005 | 01:38 PM
Default Re: SOHC ZC VTEC info needed plz, asap! (JoKarma)
umm its okay.... it pulled the same as the d16z6...but i havent drove it that hard like my old motor...scare i might blow this one too.... the highest i drove on it was 125mph thats it...
civicboy420
10
Aug 29, 2011 12:14 PM
SIR EF9
Feb 13, 2009 03:54 PM
schwenk
Jul 17, 2007 08:22 AM
J-Spec EG
Nov 14, 2004 09:20 AM
94eg4
Feb 6, 2004 07:32 AM
