Crower 63403 or Skunk2 Stage 3's?
Old Feb 16, 2005 | 09:52 AM
EF'n Sedan's Avatar
Default Crower 63403 or Skunk2 Stage 3's?
which cam would be better for 12:5:1 B18C1 with a mildly ported head and valve train!!!!
crower 63403 or skunk2 stage 3's
car will be a weekend street beast and sometimes daily driven!!!
Old Feb 16, 2005 | 11:26 AM
soLSvtec12kcraze's Avatar
both are good cams, check out importreview.com in the dyno section....or under honda-tech.com in the search section.
Old Feb 16, 2005 | 02:02 PM
jdmcx's Avatar
Default Re: Crower 63403 or Skunk2 Stage 3's? (all_throttle)
i have use the crower 63403s and it is a great cam
the skunk stg3 i heard is soposed to be easy to tune and very good powerband
ask Tbone about the skunk 3
Old Feb 16, 2005 | 02:17 PM
thevanitygroup's Avatar
Default Re: Crower 63403 or Skunk2 Stage 3's? (jdmcx)
In the All Motor Shoot Out (R&D Dyno) used a spin off of the Crower 403. Its an R&D Dyno spec, call them and see if you can get it, if so, your compression sits at right about where their motor did. You should see some nice gains from it. BTW, they made over 250HP on 91 octane.
Old Mar 19, 2005 | 09:10 PM
haha....you want to see cams, look at rocket motorsports.
JUN eaters....
Old Apr 1, 2005 | 09:39 AM
{Powered by VIII}'s Avatar
Default Re: Crower 63403 or Skunk2 Stage 3's? (awwLL_muscle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awwLL_muscle &raquo;</TD></TR><TR><TD CLASS="quote">which cam would be better for 12:5:1 B18C1 with a mildly ported head and valve train!!!!
car will be a weekend street beast and sometimes daily driven!!!</TD></TR></TABLE>
anyone else have any input on either of these cams?
Old Apr 1, 2005 | 09:48 AM
PreStaged12s's Avatar
Default Re: Crower 63403 or Skunk2 Stage 3's? ({Powered by R})
Skunk2 3's need lots of compression and lots of head flow to make max power, you need at least 13:1 cr from what I have heard to get good power from Skunk2 3's, a lot of people here on HT have been raving about Buddy Club cams, maybe you should look into the Spec III's, I have heard they make good power with the set up you have, sometimes 210+ hp.
Old Apr 1, 2005 | 11:04 AM
DonF's Avatar
Default Re: Crower 63403 or Skunk2 Stage 3's? (PreStaged12s)
I have run the SK 3's on 11.5-1 and 12.5-1 engines and they do fine , a little more top than either the BC4's or Sk Pro1's. But with a fairly mild head I wouls pick the Sk Pro1's for the street.
Zero Turbo
Nov 29, 2007 12:54 PM
IntegraVTEC
Jan 15, 2006 09:34 AM
rev2ninetyper
Mar 20, 2005 05:58 PM
SIReg9
Jun 2, 2003 11:56 AM
