Where to buy F22 valvetrain parts
Old Jan 17, 2002 | 07:50 PM
smokin rubber's Avatar
Default Where to buy F22 valvetrain parts
Im planning on building up a head for my motor. Whats out there for our engines. webcam, gude, JG. For now Im just looking for something to drop on my block. Im going to buy a junked f22 to start with, so the block will get some attention eventually. For the block Im going to stay with stock crank and rods, get aftermarket pistons with a small overbore. I plan on ending up with an engine that has slightly better power than stock, but will take up to 10psi in the distant future. I have a clutch master clutch sitting in my room, ordered the flywheel today. Ordered a reman PSrack, water pump, and timing belts. I also have a complete set of prothane bushings in the mail. Hopefully I can get all these parts on my car in a months time. feb 17 autox, feb 23-24 vir. I forgot new brembo blanks and cv boots.
Old Jan 17, 2002 | 08:37 PM
NXAccordTO4B's Avatar
Default Re: Where to buy F22 valvetrain parts (smokin rubber)
A company called Race Engineering is a place where u could get top-end parts.
Old Jan 18, 2002 | 07:42 AM
brawl's Avatar
I've been on the same task for rebuilding the top end of an F22. So far the only place i've seen even off an aftermarket camshaft was Gude. Webcam only offers regrinds and you would probably just be better off with a new one. as for the other parts of the head, i havent' gotten that far yet. If you find anything though, let me know. You're the second person i've seen who actually wants to build the F22
Old Jan 18, 2002 | 07:46 AM
SOHCArchangel's Avatar
Default Re: Where to buy F22 valvetrain parts (brawl)
endyn has black nitrided valves for the f22
and crane was supposed to come out with a billet cam for our motors, all i need now is to find some titanium retainers...
Old Jan 18, 2002 | 06:26 PM
Default Re: Where to buy F22 valvetrain parts (SOHCkordVTEC)
we should start a list to send to crane, how many people want a cam for their F22 I think we have four right here. What is the benifit of the nitrided valves? Springs, who makes springs?
Old Jan 18, 2002 | 07:11 PM
ArchAngel Sabastian's Avatar
New User
Ill take my one cam please and thank you
Old Jan 19, 2002 | 05:49 AM
stainless steel valves last longer, are lighter and have better heat dissipation than the stock carbon steel crap, the black nitrided coating is for wear purposes in regards to the guides and seals and something else of which i forgot . I do like the petition idea to send to crane for them to release the *@#$ing cam for the f22b1
Old Jan 19, 2002 | 09:16 AM
John's Avatar
New User
i thought someone on here had WebCam springs... if they even make them, i don't know... but i thought i remember seeing that someone had them... or maybe i just drink too much and i'm imagining things...
Old Jan 21, 2002 | 03:44 PM
MisterB's Avatar
try ferrea they make valves, springs, and retainers for the f22
Old Jan 21, 2002 | 05:19 PM
Default Re: Where to buy F22 valvetrain parts (cl4show)
i thought ferra only had parts for Band H motors?
Old Jan 21, 2002 | 10:41 PM
I just got in my SS valve from ferrea, from my post earlier race engineering is a company that I have order all my internal parts from. I got my valves, I just order my Springs and retainers from them also. I haven't really found a place for a cam for the f22 yet............ tooo bad I should of went for the H22 swap. owell too late I have already spend too much money into the f22
Old Jan 22, 2002 | 11:37 AM
Default Re: Where to buy F22 valvetrain parts (NXAccordTO4B)
what are your plans for the motor, ie power and revs? how much did you spend on parts?
Old Jan 23, 2002 | 08:59 AM
urbanlegend21's Avatar
New User
ttt
Old Jan 23, 2002 | 09:43 PM
I spent about $1500 on pistons and Rods, $350 on SS valves, and about $550 on springs and retainers. And a whole bunch more on BS stuff like gaskets, water pump, oil pump etc...... Im trying to make sure the motor holds up to 15 pounds of boost and some NOS at the bottom end.
[Modified by NXAccordTO4B, 6:44 AM 1/24/2002]
Old Jan 24, 2002 | 06:51 AM
sounds good. let us know when it is up and hauling. good luck
Old Jan 24, 2002 | 06:54 AM
yo man, what rpm do you start to spool, and when are you at target boost?
Old Jan 24, 2002 | 11:53 AM
Before my (stock)motor blew a ring, I spoon up around 3500 @ 9 psi. Wanting to build it up to hold 15 psi.
thehatchninja
May 3, 2005 05:52 PM
Stock@$$GSR
Dec 28, 2003 07:30 AM
RyanAutry
Nov 12, 2002 05:02 PM
