Location of Radiator fan switch?
Old Feb 16, 2005 | 06:48 AM
peel17's Avatar
Default Location of Radiator fan switch?
Wheres the location of the radiator fan switch for a 2000 LS?
Old Feb 16, 2005 | 07:07 AM
Marauder's Avatar
Default Re: Location of Radiator fan switch? (peel17)
I you mean the relay, its probably under the bumper. It was on my 96 LS. There's a bolt holding a relay bracket on the drivers side bumper. It hangs inbetween the bumper and the radiator support.
Old Feb 16, 2005 | 07:18 AM
peel17's Avatar
Default Re: Location of Radiator fan switch? (Marauder)
I believe theres a Radiator fan switch as well. The Radiator fan switch tells the relay to turn on the fan if i'm correct.
The reason i'd like to find the location because my fan don't go on until it reaches
3\4 of the guage. It might be a faulty radiator fan switch.
Old Feb 16, 2005 | 07:24 AM
JimBlake's Avatar
In the thermostat housing (lower radiator hose @ the engine). It's got a 2-wire plug. It's #14. If you unplug it & jumper the wires with a paperclip your fan should run (key on).
(Don't forget it could also be an inaccurate temperature gauge.)
Old Feb 16, 2005 | 07:26 AM
Tyler1121's Avatar
Your lucky your temp goes up, on my teg my temp always runs cold unless i unplugg my fans and it runs only at 3/4
Old Feb 16, 2005 | 08:09 AM
peel17's Avatar
Default Re: Location of Radiator fan switch? (Tyler1121)
uhmm interesting.. So #14 is the Radiator fan switch?
Man.. I should of switched it while i was changeing my T Stat. Now my radiator again...
I'm not sure if its a faulty guage. Its always consistent.. Goes to 1\2 when the engine is fully warmed up. then goes 3\4 and then the fan turns on..
Old Feb 16, 2005 | 08:31 AM
JimBlake's Avatar
Mine usually sits at about 1/3 with the engine warmed up. Then the fan comes on at about 1/2 or a little above. It kinda sounds like your gauge simply reads a little high. #13 is the sender for the gauge.
I think the gauge is pretty repeatable, but not very accurate when you compare one car against another. Still, you can stick the fan switch in a pot of hot water with a thermometer & see when it closes.
Old Feb 16, 2005 | 09:39 AM
peel17's Avatar
Default Re: Location of Radiator fan switch? (JimBlake)
JimBlake - So #13 is the Radiator fan switch just to confirm right? DOn't want to get confused with #14
Old Feb 16, 2005 | 09:40 AM
peel17's Avatar
Bump.. to confirm the Radiator Fan Switch. #13 or #14???
Old Feb 16, 2005 | 09:51 AM
JimBlake's Avatar
#14 is the fan switch.
#13 is the sender for the dashboard temperature gauge.
#15 is the coolant temperature sensor for the fuel injection ECU.
Old Feb 16, 2005 | 09:52 AM
peel17's Avatar
which one should i replace first? The temp guage or the fan switch?
Old Feb 16, 2005 | 10:05 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peel17 &raquo;</TD></TR><TR><TD CLASS="quote">which one should i replace first? The temp guage or the fan switch?</TD></TR></TABLE>I guess first I'd take out the fan switch & check it's switching temperature in a pot of hot water.
In almost the same way, you can check the gauge sender. The Helm repair book says what resistance you should measure at a few different temperatures.
I don't like just buying parts - I'd rather test stuff to see which parts are bad. Maybe if either one (or both) of those are pretty cheap, then go ahead...
Old Feb 16, 2005 | 10:12 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler1121 &raquo;</TD></TR><TR><TD CLASS="quote">Your lucky your temp goes up, on my teg my temp always runs cold unless i unplugg my fans and it runs only at 3/4</TD></TR></TABLE>
wtf? you realize that at normal operating temperature, the needle should be just under 1/2, right? it shouldnt go all the way to H. 3/4 i would call overheating.
Old Feb 16, 2005 | 10:28 AM
peel17's Avatar
Default Re: Location of Radiator fan switch? (LSvtec03)
JimBlake - thanks for the pic and help. I appreciate it.
Rafe Altschuler
14
Aug 11, 2015 04:10 PM
dman81
May 28, 2014 03:20 AM
EK9JSPEC
Aug 27, 2012 09:11 PM
JH4DB858
Jan 10, 2012 07:32 PM
fast22civic22
May 31, 2007 09:34 AM
