Axle replacement, ABS or not?
Old Feb 16, 2005 | 05:34 AM
fakemike's Avatar
Default Axle replacement, ABS or not?
I have a B18c1 in my 92 hatch dx (no ABS). The engine is from a GSR with ABS.
I have a torn boot and I was looking to replace the axle. Can I use a non-ABS axle for the replacement?
TIA
BTW Split/Quick boots are trash
Modified by fakemike at 11:50 AM 2/16/2005
Old Feb 16, 2005 | 07:49 AM
fakemike's Avatar
Default Re: Axle replacement, ABS or not? (fakemike)
bump
Old Feb 16, 2005 | 07:51 AM
Luserkid's Avatar
Ask for non ABS. I remember i went to autozone and they had it.
Old Feb 16, 2005 | 08:01 AM
monicle's Avatar
you can use either the only difference is an abs ring on the axle for the sensor. since you dont have abs you could use either.
Old Feb 16, 2005 | 08:06 AM
ROOROWNS's Avatar
If you get the one for ABS you just tap the little ring gear off of the axle.
sean
Old Feb 16, 2005 | 08:09 AM
monicle's Avatar
Default Re: (EG_Black_Hatch)
no you can just put it on. I had abs front axles on my car after the swap now I have 1 abs and one non abs it makes no difference whatso ever. just put em on there.
Old Feb 16, 2005 | 08:12 AM
FERIOkid's Avatar
Default Re: (monicle)
no abs, no need for abs axle.IF you had abs and put a non abs axle in your car your abs light would come on.
Old Feb 16, 2005 | 08:15 AM
t0p_sh0tta's Avatar
Default Re: (slowdx9585)
Can't you remove the abs rings by tapping them off with a hammer?
Old Feb 16, 2005 | 08:16 AM
egsleepercivic's Avatar
get what ever they have in stock, p/n 8063 was a non-abs integra axle at Autozone, but there are many part#s for the same axle at autozone
Old Feb 16, 2005 | 10:56 AM
B18C2_sedan's Avatar
Default Re: (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">Can't you remove the abs rings by tapping them off with a hammer?</TD></TR></TABLE> Do not remove the ring gear. Just leave it on if you do not have abs. Either axle will work (abs or non-ABS). If you remove the rings you might not get the core charge back.
Old Feb 16, 2005 | 11:31 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (B18C2_sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C2_sedan &raquo;</TD></TR><TR><TD CLASS="quote"> Do not remove the ring gear. Just leave it on if you do not have abs. Either axle will work (abs or non-ABS). If you remove the rings you might not get the core charge back. </TD></TR></TABLE>
yes... dont' remove the ABS ring, it will NOT affect a NON ABS vehical in anyway. either or will work.
Old Feb 16, 2005 | 11:52 AM
fakemike's Avatar
Default Re: (Built B16A)
Thanks Everybody
Have some
Old Feb 20, 2005 | 03:15 PM
al4t1gbundy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 &raquo;</TD></TR><TR><TD CLASS="quote">no abs, no need for abs axle.IF you had abs and put a non abs axle in your car your abs light would come on.</TD></TR></TABLE>
God dammit, i think thats what this mechanic did to my accord.
97 v6, right axle broke. Had abs before taking it in. He replaced it, now the light is on. Any way to fix, other then get another axle? is my abs still there?
Old Feb 20, 2005 | 04:16 PM
eK9aT10pSi's Avatar
you can use either but the abs one like $10+ more
EG civic
Nov 11, 2020 11:44 PM
rhdins
Sep 19, 2009 08:17 AM
j0keefe21
Feb 14, 2009 08:13 PM
felixjr18
Dec 21, 2008 07:22 PM
94_teggy_rs
Jan 28, 2008 08:36 PM
