Yup Another CTR LS/Vtec Question
Ive read over and over again about the compression ratio with CTR in a LSVtec.
I want to run a GSR head of course it will be built with 43mm ITB. But according to Omniman the compression ratio is too high for street use
lsvtec with gsr head and ctr pistons
head Gasket 2.8cc big vol= 495.6cc
piston dome vol. 6.3cc small vol= 37.2cc stock gsr/lsvtec=13.3
camber vol. 42cc
deck height .25mm 1.3cc
cyl vol. 458.4cc
Is this accurate?
According to the Compression Calculator my compression will be 12.4
so whats true?
camber vol. 42cc
cyl vol. 458.4cc
Is this accurate?
so whats true?
12.27 according to http://www.c-speedracing.com/h...c.php
READ THE THREAD STICKIED AT THE TOP OF THIS FORUM. I WOULD TRUST OMNIMAN OVER A COMPRESSION CALCULATOR. and yes its he's right 13.3:1. there are several things the compression calculator doesnt factor in which give you inaccurate data
to omniman
to omniman
Omniman is correct. Most compression calculators dont take into account the PDH of CTR pistons.
For street you can use them, but make sure you have a great tune and run the highest octane gas you can. I would personally go with a lower C/R on the street.
johnzm
566
Mar 19, 2013 05:13 AM
swaytec360
Jan 14, 2005 05:11 PM
