When doing 2-1 meges how are you making them match up?
Old Feb 16, 2005 | 12:10 AM
Kwuaymaikrup's Avatar
Default When doing 2-1 meges how are you making them match up?
Are you guys cutting little triangle pieces to fill in the gaps or what? I cannot seem to find any closeups of these transitions and was wondering what the most common techinique is.
Old Feb 16, 2005 | 07:07 AM
Default Re: When doing 2-1 meges how are you making them match up? (Kwuaymaikrup)
Anyone?
Old Feb 16, 2005 | 09:15 AM
Engloid's Avatar
OG Fabricator
If you cut the parts right, you shouldn't have any gaps.
Look up the writeups on 4-2 collectors...then do the same thing, but don't make 2 cuts per pipe. That will get you started.
Old Feb 16, 2005 | 02:46 PM
Default Re: When doing 2-1 meges how are you making them match up? (Engloid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">If you cut the parts right, you shouldn't have any gaps.
Look up the writeups on 4-2 collectors...then do the same thing, but don't make 2 cuts per pipe. That will get you started.</TD></TR></TABLE>
I understand that. My question is after you have a 2 pipe merge how do you get a smooth transition into 1 pipe? Get my drift? Say you take two 2" pipes and merge them together now you take those and put it to a 2.5" pipe.....
LukieLuc
Dec 3, 2007 07:22 AM
EGhatch33
Mar 15, 2006 06:35 PM
B16CRXT
Mar 14, 2005 02:34 PM
Sport_Injected
Oct 30, 2004 04:34 AM
Sprockets
Aug 2, 2004 11:39 PM
