Wet Nitrous Help
Old Feb 15, 2005 | 09:52 PM
rIceNOodles's Avatar
Default Wet Nitrous Help
I have a 99 accord coupe 5 speed with a F23 motor. I'm trying to install a wet nitrous kit but im having trouble finding the fuel line where i can tap it. Any suggestions? either i find it or i might have to run a dry setup which i dont wanna do.
Thanks
Old Feb 15, 2005 | 10:08 PM
raceACCORDingly's Avatar
if you have an aftermarket fuel rail you and tap there. or you can cut the line from the fuel filter to the rail and put the T fitting.
Old Feb 16, 2005 | 07:06 AM
TxTuner
Guest
Posts: n/a
Default Re: (raceACCORDingly)
gotta love NNNAAAAAWWWWWSSSSS!!!!!
Old Feb 16, 2005 | 09:57 AM
The problem is, i cant seem to find where the fuel filter is, but i do see a fuel line the size of a nickle, went to a speed shop and said not to cut into there because its high pressure. Where is the fuel filter mounted by?
Old Feb 16, 2005 | 10:01 AM
90boostdaccord's Avatar
Default Re: (rIceNOodles)
the fuel filter should be on the passenger side on the firewall
Old Feb 16, 2005 | 10:55 AM
v4lu3s's Avatar
RTFM
the easiest way to install is cut that line they told you not to cut, put a T on it and thats your fuel feed for the fuel solenoid.
Old Feb 16, 2005 | 02:09 PM
Nick H's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rIceNOodles &raquo;</TD></TR><TR><TD CLASS="quote">went to a speed shop and said not to cut into there because its high pressure</TD></TR></TABLE>
of course it's high pressure, it's a fuel line...
Old Feb 17, 2005 | 11:39 AM
SPEED FoRCE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rIceNOodles &raquo;</TD></TR><TR><TD CLASS="quote">The problem is, i cant seem to find where the fuel filter is, but i do see a fuel line the size of a nickle, went to a speed shop and said not to cut into there because its high pressure. Where is the fuel filter mounted by?</TD></TR></TABLE>
did they say that was a bad thing? parts people are usually failed mechanics heh.
Old Feb 17, 2005 | 11:43 AM
GDM Z28's Avatar
Default Re: (di3go)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by di3go &raquo;</TD></TR><TR><TD CLASS="quote">
did they say that was a bad thing? parts people are usually failed mechanics heh.</TD></TR></TABLE>
lmfao.....btw for a wet n2o kit i would think you wanted a high pressure line to make sure you get fuel....also i know someone with a b16 on spray that uses the return fuel line as the fuel line and it works fine.
Old Feb 17, 2005 | 05:31 PM
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">the easiest way to install is cut that line they told you not to cut, put a T on it and thats your fuel feed for the fuel solenoid.</TD></TR></TABLE>
exactly what i said earlier. your parts shop is trippin.
i did mine this way as well. hasnt leaked for over 2 yrs.
Old Feb 17, 2005 | 09:11 PM
lol, he said something about how i needed someone to custom fabricate a T to support the high pressure. raceaccordingly, where did you get your T at?
Old Feb 17, 2005 | 10:35 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rIceNOodles &raquo;</TD></TR><TR><TD CLASS="quote">lol, he said something about how i needed someone to custom fabricate a T to support the high pressure. raceaccordingly, where did you get your T at?</TD></TR></TABLE>
bro any T from like napa will work.....i think you need to find a new mechanic lol
Old Feb 17, 2005 | 10:48 PM
came with my NX kit
Old Feb 20, 2005 | 09:36 AM
raceaccordingly, can i get a closer shot of that t you have there? It's cool if you cant.
thanks
Old Feb 23, 2005 | 09:25 AM
so this is where I T it from?
Old Feb 23, 2005 | 12:10 PM
notoriousB's Avatar
that's it!
BTW there is no fuel filter in the engine bay for a 98-02 accord
Old Feb 24, 2005 | 05:18 AM
BlkChryKord's Avatar
so this is where I T it from? </TD></TR></TABLE>
That's the line I used.
Single-Cam
Nov 5, 2014 07:01 AM
AaronJ
May 20, 2005 12:23 PM
mongoliandonuts
Feb 28, 2005 09:50 PM
Trike
Nov 10, 2004 11:28 AM
skratchnsnift
May 5, 2003 10:35 AM
