do i need a new flywheel with just a organic stage 1 clutch?
Old Feb 15, 2005 | 06:18 PM
RedlineShftr's Avatar
Default do i need a new flywheel with just a organic stage 1 clutch?
im getting a new clutch in my 95 accord lx and i read on the exedy website that if your flywheel is warped that it will cause chatter and mess up your new clutch... is a lghtened flywheel really worth 300+ dollars?
Old Feb 15, 2005 | 06:24 PM
AccidentproWn's Avatar
Default Re: do i need a new flywheel with just a organic stage 1 clutch? (RedlineShftr)
just get your stock one resurfaced it's like 25 bucks
Old Feb 15, 2005 | 06:25 PM
Default Re: do i need a new flywheel with just a organic stage 1 clutch? (AccidentproWn)
thats just such a pain in the *** cause id be out of a car for a day or two.... couldnt i just get it lightened at a machine shop at teh same time?
Old Feb 15, 2005 | 06:43 PM
TxTuner
Guest
Posts: n/a
The lighter flywheel allows your engine to rev faster. Good thing is it improves acceleration....Bad thing is you lose gas mileage
Old Feb 15, 2005 | 08:07 PM
typhoon's Avatar
Default Re: do i need a new flywheel with just a organic stage 1 clutch? (TxTuner)
I know it revs up faster. Also your revs drop faster while shifting, but how does it effect the gas milage?
Old Feb 15, 2005 | 11:19 PM
Eddiebx's Avatar
it doesnt do jackshit for mileage, unless you like to rev-match and heel-toe all day long through traffic, its useless, just machine your stock one to clean up the surface, don't bother lightening it
Old Feb 16, 2005 | 08:16 AM
TxTuner
Guest
Posts: n/a
Default Re: (Eddiebx)
Will you be driving on the Highway? Think about cruising in 5th gear at 4500 RPM at 65-70 mph.... tell me that does'nt take away gas mileage :Dumb MFer:
Old Feb 16, 2005 | 08:25 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (TxTuner)
Just less reciprocating mass... Never a bad thing.
Old Feb 16, 2005 | 08:30 AM
TxTuner
Guest
Posts: n/a
Default Re: (LSVTEC 91 Civic)
Like the quote in your sig LS
Old Feb 16, 2005 | 09:15 AM
typhoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">The lighter flywheel allows your engine to rev faster. Good thing is it improves acceleration....Bad thing is you lose gas mileage</TD></TR></TABLE>
So your point is since it takes less effort to get it up to redline your going to use more fuel in city driving, with all the stop and go?
It would not effect milage while cruising at constant speed though.
Old Feb 16, 2005 | 09:38 AM
TxTuner
Guest
Posts: n/a
Default Re: (typhoon)
Precisely
Old Feb 16, 2005 | 01:26 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">Will you be driving on the Highway? Think about cruising in 5th gear at 4500 RPM at 65-70 mph.... tell me that does'nt take away gas mileage :Dumb MFer: </TD></TR></TABLE>
I don't really follow, are you saying that putting a lighter flywheel will shorten your gear ratio and make you rev higher when cruising?
Old Feb 16, 2005 | 03:31 PM
Tad's Avatar
Tad
wtf,
dude you're trippin man,
a lightweight flywheel is NOT going to change your GEARING
you are going to have the same rpm at the same speed no matter what you do
to your engine or clutch. The only thing that can change that is the overall size or your wheels/tires, and the gearing inside your transmission.
I have never heard anyone say a lw flywheel will affect your gas mileage either.
i mean, in the longrun it might, cuz your engine will be more fun to drive so you'll mash on it more often. And you do have to give it some more gas to get going from a dead stop too...
but it's not actually affecting your mileage.. just how you drive..
Old Feb 16, 2005 | 04:03 PM
TxTuner
Guest
Posts: n/a
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">And you do have to give it some more gas to get going from a dead stop too...</TD></TR></TABLE>
Nuff said
Old Feb 16, 2005 | 05:06 PM
SpoonFull's Avatar
I installed my Spoon 9lb Flywheel on my GS-R. Still go about 80mph at 4grand. No difference. As far as the gas mileage goes, I don't seem to notice any difference.
Old Feb 16, 2005 | 06:27 PM
Default Re: (SpoonFull)
when i take my flywheel to a machine shop to get resurfaced im gonna have them lighten it too... how much should it be lightened? anyone know what the stock weight on a 95 accord lx flywheel is?
Old Feb 16, 2005 | 11:08 PM
Eddiebx's Avatar
Nuff said
dood do you have a lightened flywheel and documented gas mileage loss? i used to get 30mpg on the h22 with i had the lightened flywheel.
and if you need to rev it alot to move from a stand still it just means you suck at driving
Old Feb 17, 2005 | 12:38 AM
Tad's Avatar
Tad
Default Re: (RedlineShftr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlineShftr &raquo;</TD></TR><TR><TD CLASS="quote">when i take my flywheel to a machine shop to get resurfaced im gonna have them lighten it too... how much should it be lightened? anyone know what the stock weight on a 95 accord lx flywheel is?</TD></TR></TABLE>
dont go lighter than like 11-13lbs, somewhere in that range.
12 is the sweet spot probably.
Old Feb 17, 2005 | 03:12 AM
raceACCORDingly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
and if you need to rev it alot to move from a stand still it just means you suck at driving</TD></TR></TABLE>
werd
Old Feb 19, 2005 | 06:12 PM
wed3k's Avatar
i wish i could FIND a machine shop that resurfaces around here.
Old Feb 19, 2005 | 06:26 PM
Tad's Avatar
Tad
Default Re: (wed3k)
its not ez to find,
ask at your local import/tuner shop they would know,
and alot easier than going thru the yelo pages or something.
i tried that.. there are ALOT of machine shops out there..
most of them wont know wtf ur talking about, haha.
Old Feb 19, 2005 | 08:17 PM
wed3k's Avatar
bay area? you know any in the peninsula?
i called this one place and they recommended me a Colelith (sp?) in burlingame, Clark's Machine shop in Redwood City or even Napa Auto parts...
fowler!
Aug 3, 2021 03:12 AM
DC5mike
Dec 25, 2008 07:54 AM
eg4life1202
Dec 29, 2006 11:28 AM
Vtecfool
Mar 28, 2004 09:29 PM
