Removing intake mani gasket CLEANLY ???
Old Feb 15, 2005 | 05:17 PM
Tad's Avatar
Tad
Default Removing intake mani gasket CLEANLY ???
OK, i'm going to have to pull the IM off my next motor..
now I do NOT want to have to go through scraping that gasket again!!!
it makes such a mess, takes for ever, and is kinda scary(dont wana scratch the surface). Plus the gasket remover spray leaves wierd residue allover everything...
So is there anything I can do to keep that gasket from leaving half of itself on
the head?? Like heating it up.. or cooling it down.. or SOMETHING !?!
lmk
thanks.
Old Feb 15, 2005 | 05:33 PM
Soccerking3000's Avatar
Default Re: Removing intake mani gasket CLEANLY ??? (Tad)
acid lol, it's probably going to break and adhere to the head no matter what you do... at least thats has been my experiences, better get ready for scraping
Old Feb 15, 2005 | 05:36 PM
turboxsi's Avatar
Default Re: Removing intake mani gasket CLEANLY ??? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">better get ready for scraping </TD></TR></TABLE>
I second that!!
Old Feb 15, 2005 | 05:44 PM
Tad's Avatar
Tad
Default Re: Removing intake mani gasket CLEANLY ??? (turboxsi)
Old Feb 15, 2005 | 05:45 PM
perlmeister8's Avatar
Gasket remover I used it and it works great, dont know about the wierd residue
Modified by perlmeistere81 at 6:55 PM 2/15/2005
jlacoy82's Avatar
71.192.16.183
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Its not what I wanted to hear either, Tad.
Old Feb 15, 2005 | 09:06 PM
ironcheftony's Avatar
dremel / something that sands and can get to those spots
Old Feb 15, 2005 | 09:30 PM
SOHC4life 96's Avatar
Default Re: (ironcheftony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emerika &raquo;</TD></TR><TR><TD CLASS="quote">Don't you hate trying to scrap the old gasket off the head and manifold to get a clean mating surface???
Spray WD-40 on the gasket before installation. Next time you pull the manifold off, the gasket comes off easy and you can re-use </TD></TR></TABLE>
Old Feb 15, 2005 | 09:35 PM
Marauder's Avatar
Default Re: (SOHC4life 96)
gasket scrapper
To help prevent it sticking next time, you can coat the gasket just around the intake ports with white lythium grease.
Old Feb 15, 2005 | 09:36 PM
tcr03's Avatar
Default Re: (Marauder)
get a hondata gasket for your new one. never have to scrape again.
Old Feb 15, 2005 | 10:14 PM
buckNasty's Avatar
Default Re: (tcr03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcr03 &raquo;</TD></TR><TR><TD CLASS="quote">get a hondata gasket for your new one. never have to scrape again.</TD></TR></TABLE>
Tad's Avatar
Tad
Default Re: (tcr03)
oh i've got a insulating gasket(forget the brand but same thing as hondata)
but im going to need to swap my jrsc onto my next motor..
Old Feb 15, 2005 | 11:17 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony &raquo;</TD></TR><TR><TD CLASS="quote">dremel / something that sands and can get to those spots</TD></TR></TABLE>
you gotta becareful when using regular sanding pads on that, the aluniminm is easy to **** up.
what i suggest you do is use a sharp razor and scrape it, if your careful you wont scratch the surface at all
journeyquest
Aug 4, 2014 06:39 AM
Colombiano127
12
Jan 3, 2008 02:34 PM
actionfigure
Jan 7, 2007 07:06 AM
WOODman
Jun 6, 2005 04:08 PM
