swapped primary o2 problems
Old Feb 15, 2005 | 01:28 PM
PuiPui's Avatar
Default swapped primary o2 problems
i have a b16 out of a 99 si into a eg (eh) chasis. I used a OBD II gsr engine harness and a rechipped p28.
I am throwing code 1 - primary o2 sensor
I extended the primaryo2 sensor from the si, however i used thicker gauge wire (only thing laying around) and i soldered them togeather, wrapped in electrical tape and plugged it in. Right when i start the car, a CEL comes on, and reads at primary o2
I reset the ECU and start the car and again RIGHT AWAY the cel comes on and reads primary o2.
I think switched the postion of the black wires that i soldered thinking i did it wrong, and same thing happens.
Can anyone help me out here? is the problem that i used much thicker gauge wires? Ive always thought that it would take a minute or two for a CEL to come on if its a o2 problem. But it seems to come on right when the car starts.
Opinions? Faulty o2? Bad soldering? Im just dumb?? Dont want to spend the money on a new o2 sensor if i don't have to.
Also 1 last question, is the plug for the primary o2 sensor the same size/shape as the plug of the 2ndary o2? Thanks!
Nooget
13
Aug 14, 2010 08:12 PM
teg2000gs
Oct 26, 2004 11:02 AM
coldfiremx
Aug 17, 2002 11:31 AM
99CivicSi
Apr 22, 2002 04:27 PM
B6teen
Jan 20, 2002 01:06 PM
