High compression required for aggressive cams?
Old Feb 15, 2005 | 12:50 PM
fsp31's Avatar
Default High compression required for aggressive cams?
I did some searching but didn't find a scientific explanation...
I'm not understanding the relationship between aggressive cams (like an s2s2) and higher compression. Why is 11:1+ compression required to run a more aggressive cam?
Thanks.
Old Feb 15, 2005 | 01:16 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: High compression required for aggressive cams? (fsp31)
Long duration cams will reduce compression, because the valves are open for a longer period of time.
Old Feb 15, 2005 | 03:22 PM
drdisco69's Avatar
Default Re: High compression required for aggressive cams? (LSVTEC 91 Civic)
Dynamic compressing is more important than static compression. Lots of overlap usually reduces dynamic compression. More static compression is needed to make up for this.
Old Feb 15, 2005 | 04:46 PM
one slow coupe's Avatar
here this may help....
http://www.team-integra.net/se...D=233
or
http://www.team-integra.net/se...D=472
Old Feb 15, 2005 | 05:19 PM
jlacoy82's Avatar
71.192.16.183
Default Re: High compression required for aggressive cams? (Honda_b16a2)
I had the same question a few days ago. It was explained to me like above, but was also said that because of the long duration and overlap, you may actually lose power as compared to a less aggressive cam w/ less overlap/duration.
Old Feb 15, 2005 | 05:22 PM
DavidT or VajT's Avatar
Default Re: High compression required for aggressive cams? (jlacoy82)
It's not required, you car will just run a lil better
Old Feb 15, 2005 | 07:11 PM
fsp31's Avatar
Great!!! Thanks!!!
That explained it very well. I guess I never realized just how long the intake valves remain open after the piston leaves BDC...
Edit:
With regards to a compression check... It seems like a compression check would yield relatively lower numbers on a motor with an aggressive cam vs. the same motor with a milder cam. The increased duration on the wild cam would result in at least a few psi lower, wouldn't it?
Old Feb 15, 2005 | 08:13 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fsp31 &raquo;</TD></TR><TR><TD CLASS="quote">lower numbers on a motor with an aggressive cam vs. the same motor with a milder cam</TD></TR></TABLE>
Bingo. After the piston passes BDC and the valves are still open, it's just pushing air back out of the cylinder instead of compressing it.
Old Jun 6, 2005 | 01:11 PM
Phatch99's Avatar
Default Re: High compression required for aggressive cams? (drdisco69)
So what are the most agressive cams u can put in a vtec head without having to upgrade your valvetrain???
Old Jun 6, 2005 | 02:56 PM
oldskool teggy's Avatar
Default Re: High compression required for aggressive cams? (Phatch99)
if you mean ITR valvetrain.. i would be hesitant to put anything bigger than a skunk2 stage 1 or similiar
Old Jun 6, 2005 | 05:10 PM
omgwtfhaxnub's Avatar
good info
Old Jun 7, 2005 | 05:18 AM
Phatch99's Avatar
Default Re: High compression required for aggressive cams? (Oldskool teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oldskool teggy &raquo;</TD></TR><TR><TD CLASS="quote">if you mean ITR valvetrain.. i would be hesitant to put anything bigger than a skunk2 stage 1 or similiar</TD></TR></TABLE>
what about b16a2 and b18c1 heads?
integra123
May 10, 2006 01:05 PM
silversly
Dec 18, 2004 08:02 AM
Dan GSR
Aug 27, 2004 07:15 PM
evo
Jun 12, 2002 03:45 PM
HX_Guy
Aug 22, 2001 02:00 PM
