timing belt loose....PICS!!
Old Feb 15, 2005 | 11:04 AM
boosted ek's Avatar
Default timing belt loose....PICS!!
i've tried everything to tighten it. won't work. un-tighten the tensioner turn crank 3 tooth, tighten tensioner...won't work. does this **** look normal? i don't want to open up the crank pulley and lower timing belt cover again but i'm afraid i have to....
Old Feb 15, 2005 | 11:06 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: timing belt loose....PICS!! (boosted ek)
That definatly is NOT normal... your asking for a slipped belt. Did you recently change it? Right belt for that block? Change the tensioner? Etc.
Old Feb 15, 2005 | 11:08 AM
POE's Avatar
POE
what motor setup is this?
Old Feb 15, 2005 | 11:12 AM
1.8's Avatar
1.8
Default Re: (Vtecin94dx)
how do u fix that? i'm having the same problem....
i got the right belt, new tensioner, spring, etc....
Old Feb 15, 2005 | 11:16 AM
Alexander's Avatar
have you replacing the tensioner spring with a new OEM spring?
Old Feb 15, 2005 | 11:20 AM
endlesswinterco's Avatar
Default Re: timing belt loose....PICS!! (Alexander)
bolts on the cam gears could have slipped?
Old Feb 15, 2005 | 11:22 AM
POE's Avatar
POE
Default Re: timing belt loose....PICS!! (RidinlowHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinlowHatch &raquo;</TD></TR><TR><TD CLASS="quote">bolts on the cam gears could have slipped?</TD></TR></TABLE>
nahhh
Old Feb 15, 2005 | 11:31 AM
1.8's Avatar
1.8
Default Re: timing belt loose....PICS!! (Vtecin94dx)
how do u fix that? i read about the coathanger trick. will that help? do u do the coat hanger with the tensioner loose or tight?
Old Feb 15, 2005 | 11:45 AM
shivic's Avatar
tighten the intake cam more
Old Feb 15, 2005 | 11:52 AM
1.8's Avatar
1.8
Default Re: timing belt loose....PICS!! (shivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shivic &raquo;</TD></TR><TR><TD CLASS="quote">tighten the intake cam more</TD></TR></TABLE>
they both look at TDC though.
Old Feb 15, 2005 | 12:15 PM
Ignitecivic's Avatar
Default Re: timing belt loose....PICS!! (1.8)
damn that shiet dosnt look normal. u can even take the belt out easily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted ek &raquo;</TD></TR><TR><TD CLASS="quote">i've tried everything to tighten it. won't work. un-tighten the tensioner turn crank 3 tooth, tighten tensioner...won't work. does this **** look normal? i don't want to open up the crank pulley and lower timing belt cover again but i'm afraid i have to.... </TD></TR></TABLE>
that method should work though cuz i tried it and it works
Old Feb 15, 2005 | 12:42 PM
Farmer Brown's Avatar
Default Re: timing belt loose....PICS!! (Ignitecivic)
Run it until it tightens up.
Looks like you either have the wrong belt or you need a new tensioner. Or need to learn how to adjust it right.
Old Feb 15, 2005 | 01:07 PM
RCautoworks's Avatar
Default Re: timing belt loose....PICS!! (Djaric)
If you follow the proper instructions and it still not not get tight, re follow the directions but pull up on the tensioner. This will increase the tension and fix the loose belt problem.
Old Feb 15, 2005 | 01:16 PM
debo*'s Avatar
Default Re: timing belt loose....PICS!! (90blackcrx)
i wouldnt drive that.
Old Feb 15, 2005 | 01:27 PM
SPOOLINmatt's Avatar
Default Re: timing belt loose....PICS!! (debo*)
lol cam gears bolts slipping wouldnt cause that...that makes the actual cam move inside the cam gear, you can loosen both all the way and move the gears all you want but it wont effect the BELT!!. use your brains!!
Old Feb 15, 2005 | 01:44 PM
johnzm's Avatar
Default Re: timing belt loose....PICS!! (SP00LIN)
i have had to deal with this before. the cam marks or something to that effect is way off, causing there to be a giant loose part in the middle of the cam.
al you can do is dial each cam out accordingly until the loseness is moved to where the tensioner can take t out.
i would do it, since u have cam geat just throw them back where u think they should go for the time being.
Old Feb 15, 2005 | 02:04 PM
Default Re: timing belt loose....PICS!! (johnzm)
the cam horizon marks are what need to be lined up with you install the belt. they need to be side by side. put all your slack on the right side(waterpump side). it doesnt matter what happens to the adjustment bolts on the cam gears, it wont affect the tension. if you are driving and the adjustment bolts on both gears came loose...on both...and one went all the way retarded and the other advanced...the belt tension will be unchanged. and your motor would explode
Old Feb 15, 2005 | 02:27 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
if you have a shaved head, decked block, or even a thinner headgasket, you will effectively "lengthen" the timing belt. you will need to manually pull up on the tensioner. i have done this many many times. simple.
Old Feb 15, 2005 | 02:34 PM
johnzm's Avatar
man theres too much to type. ive had this issue a few times, like the gears are cut wrong or something.with that much slack im sure u can pop another tooth over the cam gear and get it taught up there. mine were the other way tho, they weer a half tooth loose and i had to play with the cams alot until none of the marks were aligned perfectly to get the tension where it was correct. at that point since the marks arent lined up i would do a "ghetto" cam gear setiing to compensate for my shitty belt/inability to get all the marks lined up.
teler86
May 5, 2006 08:48 AM
Haleiwa-Brando
Apr 14, 2006 11:17 AM
Crosbydp
Jan 3, 2006 07:27 PM
Finest
Oct 19, 2004 07:34 AM
integmester
Jul 2, 2004 05:38 PM
