HELP!
Old Feb 15, 2005 | 08:09 AM
93_cxEG's Avatar
Default HELP FIX THIS ITS MY CAR!
okay! i trade my eg hatch for a del sol and the horn does not function at all in other words it does not work...i check the fuse box and it look fine....any suggestion...
Modified by 93_cxEG at 1:11 PM 2/23/2005
Old Feb 15, 2005 | 08:38 AM
93_cxEG's Avatar
Default Re: HELP! (93_cxEG)
any suggestion....well.........................
Old Feb 15, 2005 | 08:58 AM
95cxhatch's Avatar
horn is probly rusted to fawk and won't work ....take the bumper off and check it out
Old Feb 15, 2005 | 09:05 AM
93_cxEG's Avatar
Default Re: HELP! (95cxhatch)
i did everything seems connected...
Old Feb 15, 2005 | 09:20 AM
95cxhatch's Avatar
yah the wires may be connected but the actual horn assembly may be too rusted to be able to make a sound..... mine was like that anyway
Old Feb 15, 2005 | 09:25 AM
dantastic's Avatar
buy a multimeter and test away! you can buy a multimeter + timing light @ kragen for $30 after rebate!
Old Feb 15, 2005 | 11:18 AM
93_cxEG's Avatar
Default Re: (dantastic)
okay...i'll try that...
Old Feb 15, 2005 | 12:08 PM
Del Sol SiR's Avatar
or just run 2 wires from your horn to the battery to test it. If it works, maybe something is disconnected on the steering wheel side. For instance, is there a factory steering wheel on there ? Sometimes the horn is not connected on the aftermarket steering wheels on Del Sols, because it requires some re-wiring work.
Old Feb 15, 2005 | 01:46 PM
93_cxEG's Avatar
Default Re: (DelSolSiR)
thanks...
Old Feb 15, 2005 | 01:50 PM
johnzm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSiR &raquo;</TD></TR><TR><TD CLASS="quote">or just run 2 wires from your horn to the battery to test it. If it works, maybe something is disconnected on the steering wheel side. For instance, is there a factory steering wheel on there ? Sometimes the horn is not connected on the aftermarket steering wheels on Del Sols, because it requires some re-wiring work. </TD></TR></TABLE>
be sure t run the wire from the battery to the horn, u want ur ear right next to it, when u try it because the 12 volts isint enough juice and make the horn real quiet, so get ur ear as close as u can to the horn!
Old Feb 16, 2005 | 08:24 AM
93_cxEG's Avatar
Default Re: (johnzm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">
be sure t run the wire from the battery to the horn, u want ur ear right next to it, when u try it because the 12 volts isint enough juice and make the horn real quiet, so get ur ear as close as u can to the horn!</TD></TR></TABLE>
oh okay i'll do that...WTF...who do you think i am...i know that **** is going to be loud u DF....man your ruin my thread get out....
Old Feb 16, 2005 | 08:29 AM
Pioneer162's Avatar
Default Re: (93_cxEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG &raquo;</TD></TR><TR><TD CLASS="quote">
oh okay i'll do that...WTF...who do you think i am...i know that **** is going to be loud u DF....man your ruin my thread get out.... </TD></TR></TABLE>
I'm surprised you haven't been flamed, or docked because of the thread title....you're ruining the forums...get out or read the rules.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Rules &raquo;</TD></TR><TR><TD CLASS="quote">2.A. Please do not post misleading or unspecific thread titles. Please don’t post “Help Needed” or “Look at this problem.” Make your thread titles specific to the question you are asking</TD></TR></TABLE>
Old Feb 16, 2005 | 11:04 AM
B18C2_sedan's Avatar
Hey man do forget about the ground. It's just as important as power.
Old Feb 17, 2005 | 07:27 AM
93_cxEG's Avatar
Default Re: HELP! (B18C2_sedan)
okay tried hooking it up to the battery and the horn works...so can it be any wire or the steering wheel...
Old Feb 17, 2005 | 07:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG &raquo;</TD></TR><TR><TD CLASS="quote">okay tried hooking it up to the battery and the horn works...so can it be any wire or the steering wheel...</TD></TR></TABLE>
It'd be the horn wire in the steering wheel... do you have SRS in your sol ?
Old Feb 17, 2005 | 08:12 AM
93_cxEG's Avatar
Default Re: HELP! (DelSolSiR)
yup i have sr5...hmm how would i connect the horn then...oh yeah my del sol year is a 95 model...its a S model...
Old Feb 17, 2005 | 08:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG &raquo;</TD></TR><TR><TD CLASS="quote">yup i have sr5...hmm how would i connect the horn then...oh yeah my del sol year is a 95 model...its a S model...</TD></TR></TABLE>
is your SRS light on on your cluster ? reason why I ask is because there is a harness underneath the steering column, it has a yellow plug which connects both the SRS and horn.
Old Feb 17, 2005 | 08:21 AM
93_cxEG's Avatar
yeah it does comes on...yeah...and is there a way where i can by pass that and make it work.
Old Feb 17, 2005 | 08:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG &raquo;</TD></TR><TR><TD CLASS="quote">yeah it does comes on...yeah...</TD></TR></TABLE>
is it on constantly?
Old Feb 17, 2005 | 08:23 AM
93_cxEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG &raquo;</TD></TR><TR><TD CLASS="quote">yeah it does comes on...yeah...and is there a way where i can by pass that and make it work.</TD></TR></TABLE>
yes its on forever...
Old Feb 17, 2005 | 08:27 AM
yes its on forever...</TD></TR></TABLE>
CK these wires!
Old Feb 17, 2005 | 08:28 AM
93_cxEG's Avatar
CK these wires!
what do u mean by CK...and which wire should i check...
Old Feb 17, 2005 | 08:45 AM
93_cxEG's Avatar
so................what is next on how to fix it...
Old Feb 21, 2005 | 08:07 AM
93_cxEG's Avatar
hmmm still not working need a expert to swing by and check it out...
Old Feb 21, 2005 | 08:24 AM
what do u mean by CK...and which wire should i check...</TD></TR></TABLE>
CK, short for Check. These are the wires that you will see when you remove your SRS on the steering wheel to see the wiring for your horn.
