d15z1 dist?
Old Feb 15, 2005 | 05:46 AM
turbo sol's Avatar
Default d15z1 dist?
well. I have a d15z1 in my car right now, I plan on putting a sohc vtec in. What is worth salvaging from the VX to use on the d16z6/y8?
does the VX dist work on a sohc vtec head?
can i reuse the vtec seliniond from the VX head?
head bolts?
Old Feb 15, 2005 | 07:39 AM
turbo sol's Avatar
Default Re: d15z1 dist? (turbo sol)
also can i interchange any 92+ d16 cranks?
Old Feb 15, 2005 | 09:45 AM
Do_Ster's Avatar
i know you will be able to use the VX dizzy on a z6 since they have the same mounting pattern. not quite sure about the y8. you should search, i remember seeing a couple of threads about this
Old Feb 15, 2005 | 09:48 AM
BauleyCivic's Avatar
Risky Business
Default Re: (_OEM_)
It will work on the Z6, but not the Y8. You'll need a B7 or B8 dizzy if you want to use a Y8 on an OBD1 car.
Old Feb 15, 2005 | 10:19 AM
turbo sol's Avatar
Default Re: (V-Tech Bauley)
a was aware about the mounting issues of an obd1 dist on the y8 head.
my car will be obd1 (even if i run thet y8 head) so my VX dist should work then right?
I might use a shell from a obd2 dist and swap internals so it mounts right and work with my chipped p28 ecu.
Old Feb 15, 2005 | 11:10 AM
Risky Business
Default Re: (turbo sol)
The bolt pattern on the Y8 is different than the Z6...read what I said
Old Feb 15, 2005 | 12:09 PM
turbo sol's Avatar
i said i was aware of the mounting issues, people have ran their dist with only 2 legs attached and such. I planned on using the obd2 shell as I stated to keep that from being a problem.
I didn't know if their were sensors inside the dist that would cause a problem.
sounds like everything will work fine. thanks.
vital123
17
Dec 22, 2009 06:04 AM
toolbox21
Jul 21, 2008 07:29 PM
greddytunedhatch
Feb 7, 2005 04:47 PM
hondacru27
Feb 12, 2004 02:55 PM
JICB16B
Jan 14, 2004 05:15 AM
