Ek-9 Power Mirror Diagram for those who need it
I was sitting there bored and i had my jdm power folding mirrors sitting in my room collecting dust so i decided to try to wire it up. What do you know i had them working the first time
Just to let you know i used the jdm oem relay for the mirrors and for those who dont have it i dont know how you would wire it up. Also i installed these on my 97 civic ex which had all the oem plugs. So here goes
Left plug - Jdm plug on mirror
Blue/ black - Blue/ black wire on oem plug
Blue/ white- Blue/white wire on oem plug
Yellow/ red - Yellow/ red on oem plug
Green/ orange - connects to green/orange wire on right mirror jdm plug then both connect to blue/red wire on relay
Green/yellow - connects to green/yellow wire on right mirror jdm plug then both connect to green/yellow wire on relay
Black - grounded
Orange/white - is not used
Right plug - Jdm plug on mirror
5 wires on the right jdm plug
3 of the wires color match to the oem wires so just connect them to it
2 left over wires which are the green/yellow which you already connected to the left green/yellow wire on the left plug and ran both to the green/yellow wire on relay
Green/orange wire which you already connect to the left green/orange wire on the left plug and ran both of them to the blue/red wire on relay
Jdm power mirror switch
All the wires are connected to the same color wires on the harness for the power mirror switch but you have one left over which is a blue/yellow wire. This wire is connected to the blue/yellow wire on the relay
Jdm/oem relay
As stated above
Green/yellow connects to both green/yellow wires jdm mirror plug
White/blue connects to a + power source
Black wire is grounded
Blue/yellow wire connects to the blue/yellow wire on the jdm mirror switch
Blue/red wire connects to both green/orange wires on both jdm mirror plugs
Hope this helps all those people who haven't figured it out yet and those who have kudos for you
Black - grounded
Jdm/oem relay
As stated above
No problem ive done so many searches and never found one so i took it upon myself to figure it out.. I hope it helps anyone whos had this problem
RabbittZ
May 11, 2003 09:49 AM
