Car studders when accererating or decelerating at lower rpms?
When even I apply the gas in the lower gears at lower rpms the car studders same thing for when I let off the gas pedal to slow down. I checked the spark plugs and they look fine. They were replaced last fall. I believe I got a new distributor, rotor and cap and new spark plug wires last spring. Basically a full tune up. After the tune up last spring it ran good till most of the summer. Now its really starting to act up again and starting to get me annoyed. What other possibilities might there be? Thanks....
when you say stutter, what do you mean? does the power cut in and out? or is there a vibration?...loss of power at low rpms?
I believe it has been replaced. Im remember reading somewhere that if I clean the egr ports it might solve the problem. What do u guys think?
engine mounts? I know my car shakes sort of violently at idle because it needs new engine mounts (I assume). I have to rev to 1k to make it sit still while I'm idling.
Its possible.....not one of the first things i would of thought of....ill have to look into it...But this is not about idling. Its about driving the car.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracin24 »</TD></TR><TR><TD CLASS="quote">Its possible.....not one of the first things i would of thought of....ill have to look into it...But this is not about idling. Its about driving the car.......</TD></TR></TABLE>
aware of that, but it could be the same issue. just throwing out suggestions
bump for you.
bump for you.
admess188
Aug 13, 2011 07:29 PM
dwaynevkao
Sep 6, 2006 07:28 PM
