Car died on the highway!! techs help!
Old Jan 17, 2002 | 01:23 PM
Malice's Avatar
New User
Default Car died on the highway!! techs help!
this sucks, but i got it started eventually, but im not sure why it died. heres the story:
i just gave the toll booth lady my money and i took off. when i got to about 6000 rpms, the car jerked. the tach went down to zero, then all the idiot lights came on. i made to the side of the road and tried to fire her up. the motor would turn, but would not start. the motor just made this sound like i tapped a hollow tube. for a second i thought i blew a gasket, but when i popped the hood i saw no fluids spashed anywhere, or on the ground. checked my dipstick to see maybe i didnt have enough oil, and it was low. checked the distributor to see if it was tight and it was. so i think its the starter. anyone else have any ideas? would the starter cause the car to die? its odd cause i'd already driven about 30 miles before it died.
ater about 30 minutes on the side of the road, it started up again. i also just had my venom injectors put in on sunday.
TIA
Old Jan 17, 2002 | 01:36 PM
HKS_All_Around's Avatar
Default Re: Car died on the highway!! techs help! (MaliceGSR)
Well I am not Sure. But I sort of Had the Same Problem. But mine was where i didn't put the Right Oktane (CAn't Spell Sorry) in my car and it caused it 2 Idle weird and Die Sometimes. Also It might been Where it hasn't been Running 4 a While. Cause My did the Same Thing and I think it was because it was in the Shop 4 like a Month or something and wasn't started 4 a while. Well I hope I sort of Helped ya out. I have a Hard Time Explaining Stuff. C-ya
Old Jan 17, 2002 | 01:52 PM
Chris's Avatar
Default Re: Car died on the highway!! techs help! (acura_man02)
WOW! What a coincidence that you just put in injectors and now you have fuel problems!
I would definately start there... Starter only starts the car...after its on..its done!
Old Jan 17, 2002 | 02:01 PM
Malice's Avatar
New User
Default Re: Car died on the highway!! techs help! (Chris)
yea that was one of the places i was going to start. unfortunately i cant do anything since i'm at work
Old Jan 17, 2002 | 11:11 PM
Vtec integra's Avatar
might be your rotor is starting to go bad
if not the injectors
Old Jan 18, 2002 | 12:26 AM
dohcgarage's Avatar
its not the starter, if its the starter, the car won't turn at all.
unless the gear isn't popping out.
your best bet is to find a buddy that have a civic or integra, swap main relay with him/her, it will most likely solve the problem. if not try the ignitor or the distributor coil.
but like I said start with the main relay first, its the easiest thing to do
Old Jan 18, 2002 | 01:25 AM
Babybluegsr92's Avatar
Default Re: Car died on the highway!! techs help! (dohcgarage)
sounds like either the coilpack or ignitor i had that happin to me on the freeway it just bogged and died. there spendy so have someone check them!!
-Joe
Old Jan 18, 2002 | 07:07 AM
junglistgsr's Avatar
main relay wouldnt cause the car to die on the highway, it would thought let the car not start and then let it start later if it was going bad....but i think the reason the car died is not an ignition problem, but a fuel problem.....
ken, is your timing all correct after your cam install?
Old Jan 18, 2002 | 08:39 AM
GTEater's Avatar
did your rpms go crazy(up and down) before your car died?......if so, its probably a problem somewhere in your distributor, but if your coil or ignitor is blown, your car wouldn't start at all.....had this problem last summer
Old Jan 18, 2002 | 08:58 AM
97integraLST's Avatar
Default Re: Car died on the highway!! techs help! (GTEater)
i ahd the same problem before... I was cruising at 80 then POP! Blac smoke PUFFF no power PUFF more black smoke, car wouldnt start... I had it towed to my mechanic and it had something to do witht the distributor... Rotor
Old Jan 18, 2002 | 09:33 AM
Default Re: Car died on the highway!! techs help! (97integraLST)
remember guys, it died.....but it started up a half hour later.....it cant be something like a ignitor or something like that because it wouldnt have started again if it was....at least to my knowledge.
Old Jan 18, 2002 | 09:41 AM
Malice's Avatar
New User
Default Re: Car died on the highway!! techs help! (junglistgsr)
i set the timimg at 17 degrees after the cam install. i will check the rotor as well. also i just double check the fuel line and injectors and everything seemed ok. i drove it home last night and i didnt have any problems. i didnt take it up to vtec at all. im gonna go check somemore. I'll post when i have an update. thanks for all the help guys
[Modified by MaliceGSR, 6:42 PM 1/18/2002]
skata89
Jan 14, 2006 10:08 AM
Its me DUB
14
May 13, 2005 09:40 AM
bpetruzzo
15
Apr 21, 2004 04:42 AM
EGsixer
Dec 11, 2002 10:23 PM
1hotintegra
Jun 3, 2002 07:08 AM
