what could be wrong?????
Old Feb 14, 2005 | 01:55 PM
game over's Avatar
Default what could be wrong?????
its a 00' civic si,i put a h22 swap in and when i went to start it nothing happen no noise or anything. when u turn the key the fuel pump comes on,everything is hook up what could be the prob?????
Old Feb 14, 2005 | 01:59 PM
Slow ass EF's Avatar
Default Re: what could be wrong????? (game over)
sounds like a bad starter. does the engine crank at all?
Old Feb 14, 2005 | 02:02 PM
NJIN BUILDR's Avatar
Wow,where to begin.Check all your connections.You can plug the wrong plugs together.Check you grounds...etc
Glenn
Old Feb 14, 2005 | 02:07 PM
game over's Avatar
nope car wont crank at all
Old Feb 14, 2005 | 02:11 PM
Default Re: (game over)
Use a test light and see if you have power to the starter when you turn the key.Is the clutch safety switch installed.
Glenn
Old Feb 14, 2005 | 02:15 PM
game over's Avatar
the car was a theif recovery.......how would i check the safety switch is hooked up
Old Feb 14, 2005 | 02:29 PM
Its under the dash on the clutch pedal linkage.Get your wiring diagram and start chasing.
Glenn
Old Feb 14, 2005 | 03:23 PM
game over's Avatar
ok .....thanks guys i got
s.langley
Feb 3, 2019 06:31 AM
killrroyale
17
Jul 12, 2013 02:28 PM
ftrms
15
Dec 22, 2010 04:05 PM
cruz_96LS
Jul 27, 2010 03:44 AM
obuhmyuh
10
May 4, 2010 02:15 PM
