Turbo Kit progress on a 99 accord
its completed now, i started a new thread with pics and dyno sheet
https://honda-tech.com/zerothread?id=1159629
about 6-7 p.s.i. and im using:
-a tial 38 mm wastegate
- small intercooler
-tial blow off valve
-a precision sc-32 t3 turbo with 480 max h.p, and a 360 race bearing system,
go to http://www.precisionturbo.net/...=3026
(its the 4th or 5th one down)
-custom built manifold and intercooler piping
- fuel pump
-apexi safc2 to control everything
and a boost gauge
-he'll do all the tuning on a dyno himself
so far all that is done is the mounting of the inercooler to the bumper
most of the ic piping is made but still not ready to put on and were waiting on the flange for the manifold to be able to be built, then its all cheese from there!
i will update again with more pictures and info soon!
Modified by hotaccord243 at 6:13 PM 2/16/2005
Modified by hotaccord243 at 6:47 PM 2/23/2005
Modified by hotaccord243 at 11:02 PM 2/23/2005
- small intercooler
- fuel pump
and a boost gauge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Hites" »</TD></TR><TR><TD CLASS="quote">awww, i was hoping for turboed j30.
Keep hoping
Nice setup, but that is quite possibly the smallest intercooler (front mount) I've ever seen. But for 6-7psi it should work great
</TD></TR></TABLE>Keep hoping
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMAccord2nr »</TD></TR><TR><TD CLASS="quote">
Keep hoping
a midengine twin turbo j30 in a shifter cart is what i thought this thread was going to be about.
Keep hoping
</TD></TR></TABLE>a midengine twin turbo j30 in a shifter cart is what i thought this thread was going to be about.
looking good, keep us updated on your progress. are you boosting the stock f-series (6th gen so i assume F23)? also what other modifications have you done or plan on doing?? best of luck to you, hope to see the project complete in the near future.
it is the stock f23a4 of the 6th gen.
i have currently on a greddy evo catback, punched out catalytic converter, shortshifter adapter, (i had dc headers and a cold air) and some new stereo (alpine), type r grille, generation 3 gunmetal projector headlights, and tein ss coilover suspension dropped about 3"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Hites" »</TD></TR><TR><TD CLASS="quote">a midengine twin turbo j30 in a shifter cart is what i thought this thread was going to be about.
HAHA!
I doubt there will ever be a successful turbo J30.
</TD></TR></TABLE>HAHA!
Update #2- the safc2 was mounted in the center console underneath the cd player today also with the fuel pump and hosing, and the fmu mounted!
sorry no pics
this time cause it wasn't that exciting anyway to look at but next time i promise pictures
Modified by hotaccord243 at 6:14 PM 2/16/2005
sorry no pics
this time cause it wasn't that exciting anyway to look at but next time i promise picturesModified by hotaccord243 at 6:14 PM 2/16/2005
update #3! the manifold is being built right now
but the fmu, vasf2, gauge pod and fuel pump and lines are all mounted! heres the pictures:
heres the mounted safc2: i know its kinda dirty but ill clean it up!!!!
heres the fmu mounted:
heres the fuel pump, there may be some changes on the line cause they stick out but here it is for now:
heres the gauge pod w/o the gauge (it hasnt come yet):
more to come soon with full engine bay pics, dyno sheet, and full pics!
but the fmu, vasf2, gauge pod and fuel pump and lines are all mounted! heres the pictures:heres the mounted safc2: i know its kinda dirty but ill clean it up!!!!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMAccord2nr »</TD></TR><TR><TD CLASS="quote">It looks to me that you have a SAFC II, not a vafc or a 'vasf'
Pwned!!! What the hell is a VASF? Did I miss something?
</TD></TR></TABLE>Pwned!!! What the hell is a VASF? Did I miss something?
Just a though...Get some T-screw drive cramps for the fuel line, those worm drive are known for getting loose over time, which you could get a pretty nasty engine fire.
you were right it is the safc2 my bad i did a typo, but i fixed it, the t-screw drive clampsi think i know what you are talking about thanks for theadvice iam7head, i will look into it. have you had any that have loosened or know any that have? could you show me what you are talking about? thanks and any more suggestions/comments would be greatly appreciated!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj »</TD></TR><TR><TD CLASS="quote">
theres enough room under the hood for a turbo, but it would be located at a totally odd location. possible, but as you said, not to be considered a success.
a j30 mounted midship in a crx might be possible, though. if you can put a supercharged 468 big block into a crx...
...i doubt a j30 could be any harder.
</TD></TR></TABLE>theres enough room under the hood for a turbo, but it would be located at a totally odd location. possible, but as you said, not to be considered a success.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotaccord243 »</TD></TR><TR><TD CLASS="quote">update #3! the manifold is being built right now
looks good. btw, i call that compartment "the abyss". a black interior makes that space look like an endless pit and it nearly is that big.
Question. If you have a SAFC why not just use it as the "HACK" and forget the FMU. Is there something im missing here.
"HITES"
Ive seen a couple kits inside the J32 compartments and a V6 Camry. They just sit where the battery is.
About the CRX, how would you get the tranny to bolt up? NSX tranny?!?!
"HITES"
about using the hack with safc2 and not use a fmu, i don't believe if i trust in the whole hack process. i have heard of too many problems with that whole idea, now im sure it works for other people but i feel much more comfortable with having an fmu rather than going the hack route.
update #4 or so:
the manifold is 3/4 done, it still needs a mount for the wastegate, and the turbo is mounted in this picture, the downpipe is almost done just needs to be connected to the cat, and then the ic piping, and gauge, oil lines, and tuning, then it is done
any comments or suggestions would be great! i am really excited ill have pics and a tyno sheet posted when its finished!
thats EXACTLY where i thought the turbo would go! after installing my cai, i noticed how much room it freed up and i later realized that relocating the battery would free up much more room. if you removed the headlight, thatd be pretty much a straight shoot into that turbo.
i dont have a clue how they got the tranny to work in that crx. im thinking the tranny on the front of the engine with the shaft redirecting back, like that of almost every 4wd truck and the early 90's acura legends for reference/example, and having the differential very close to the engine itself (would have to be) and possibly having one of the axles go through the oil pan (early 90's legend again
). in all honesty however, i dont have a clue. btw, it also has the stock engine up front for daily driving.
</TD></TR></TABLE>thats EXACTLY where i thought the turbo would go! after installing my cai, i noticed how much room it freed up and i later realized that relocating the battery would free up much more room. if you removed the headlight, thatd be pretty much a straight shoot into that turbo.
yet another update:
got the car running today, there was a leak in the manifold by the flange so hes gonna fix that tomm morning, and put a filter on that and tomm afternoon it should be done with pics and dyno sheet posted with a video of the dyno too!
