Easiest way to fill tranny fluid?
Old Feb 14, 2005 | 12:42 PM
Utilitarian's Avatar
Default Easiest way to fill tranny fluid?
Being that I've had my car over a year, it's the first car I've owned long enough to need a fluid change.
What's the easiest/ quickest way to refill the MTF without a lift? I don't have 4 jackstands to make the car perfectly level, so I'm thinking of just removing the wheel and using one small jackstand if it has any bearing.
I'll probably toss a hose on a funnel but was wondering if the speed sensor trick works on the ITR.
-Matt
Old Feb 14, 2005 | 12:43 PM
Cosworth's Avatar
Default Re: Easiest way to fill tranny fluid? (Utilitarian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote">wondering if the speed sensor trick works on the ITR.
Yes, it works. Probably the fastest way.
Old Feb 14, 2005 | 12:47 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Easiest way to fill tranny fluid? (Cosworth)
speed sensor yo
Old Feb 14, 2005 | 12:48 PM
Willard's Avatar
VSS hole = best bet.
Old Feb 14, 2005 | 12:49 PM
uNF$@#!'s Avatar
Default Re: Easiest way to fill tranny fluid? (People_Mover)
just be careful with it...its expensive to replace
Old Feb 14, 2005 | 12:52 PM
RTW DC2R's Avatar
Default Re: Easiest way to fill tranny fluid? (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">just be careful with it...its expensive to replace </TD></TR></TABLE>
and easy to break
Old Feb 14, 2005 | 12:53 PM
Haleiwa-Brando's Avatar
&lt;------ Raises hand...
I'll be the dumb guy! You fill it till it starts to over flow correct?
Aloha,
Brandon
Old Feb 14, 2005 | 12:55 PM
RTW DC2R's Avatar
Default Re: Easiest way to fill tranny fluid? (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">&lt;------ Raises hand...
Aloha,
Brandon</TD></TR></TABLE>
over flow FROM THE REGULAR FILL HOLE, NOT THE VSS HOLE. leave the regular fill hole open as you fill and stop filling when it starts to come out of the regular fill hole.
Old Feb 14, 2005 | 01:03 PM
Default Re: Easiest way to fill tranny fluid? (RTW Ryan)
) but <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan &raquo;</TD></TR><TR><TD CLASS="quote">
and easy to break</TD></TR></TABLE>
How's it break (I'm sure I could find a number of ways ), typically speaking.
Does it just pop out after removing a 10mm bolt and plug or something?
Old Feb 14, 2005 | 01:04 PM
Willard's Avatar
remove the 10mm and clean the dirt/dust from around the hole... then twist and lift out.
don't drop it.
mayfly
May 31, 2010 05:58 AM
sleepermachanic 8
May 16, 2006 07:04 PM
aser1z
Sep 7, 2005 08:17 PM
85mm LS VTEC
Mar 11, 2005 02:53 PM
Mora
Sep 29, 2003 06:58 PM
