Main Fuel Replay
Old Feb 14, 2005 | 09:26 AM
garrybloom's Avatar
Default Main Fuel Replay
I want to change out my main fuel relay on my 90 Accord but cannot locate it. Need some specifics here please.
Old Feb 14, 2005 | 09:30 AM
Turbowa's Avatar
Default Re: Main Fuel Replay (garrybloom)
Its located under the drivers side by the steering columb. Its held in place with a 10mm bolt.
Old Feb 14, 2005 | 11:31 AM
TxTuner
Guest
Posts: n/a
Default Re: Main Fuel Replay (Turbowa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbowa &raquo;</TD></TR><TR><TD CLASS="quote">Its located under the drivers side by the steering columb. Its held in place with a 10mm bolt.</TD></TR></TABLE>
Way to be specific It IS under the drivers side. It's a little gret box about 2"x2" with the manufacturer's label on it (more than likely Mitsuba)
Old Feb 14, 2005 | 02:09 PM
hondadude's Avatar
You can't see it very easy unless you remove the cruise control unit; and then when the cruise unit is it of the way you'll see the bottom of the relay where the plug is.
Old Feb 15, 2005 | 02:50 PM
Nataku's Avatar
Default Re: Main Fuel Replay (hondadude)
http://autorepair.about.com/cs...1.htm
Should be the same for a 90. I've got a 92.
nitewolf
Jan 24, 2008 09:05 PM
E.Honda
25
Nov 14, 2005 07:04 PM
slickrc
Sep 26, 2004 03:25 PM
LookingForVTEC
May 23, 2004 11:59 AM
garagespecial
Aug 22, 2003 03:41 PM
