My oil cooler setup. Did I get it right?
Paragraph Alert
1. 12ft of Aeroquip SS hose.
2. 19 Mocal oil cooler with 10an fittings.
3. 4 standard Hose ends.
4. Mocal sandwhich plate with 1/2npt inlets.
5. Two 90 degree 10an to 1/2npt adapter fittings.
Since it says the cooler has 10an fittings I can just screw my hose end directly onto the cooler without an adapter fitting correct? Would it be better to go with a 90 degree hose end at the cooler? The 90 degree fittings for the adapter plate on the block will be nessecary for clearing issues correct?
Thanks in advance.
Thanks in advance.
