Starter help???please
Old Feb 14, 2005 | 12:31 AM
nxstrikerxn's Avatar
Default Starter help???please
ok this is wat happen my car was runnin fine until i got out of coffee shop n try to start my car. The only sound that it made was click once n thats it. My power is all there n i try to jump the car n it wouldnt crank i had to push jump start the car den it was run...is this a starter problem
Old Feb 14, 2005 | 12:51 AM
Mischief_EG's Avatar
Default Re: Starter help???please (nxstrikerxn)
i would guess either that or an igniton problem
Old Feb 14, 2005 | 12:59 AM
mikehawkBUiLT's Avatar
Default Re: Starter help???please (Team_MISCHIEF_916)
there's a trick to seeing if its your starter.
there's 2 wires going to your starter.
#1 ignition wire
#2 positive cable from your battery
what you do is take off the ignition wire, and take a spare piece of wire and connect it to where the ignition wire would go on the starter. take the other end of that spare wire and touch the positive cable connected to the starter. they're right next to eachother. that'll give power to the starter to crank. if it doesn't, then you have a faulty starter, if it does then your ignition is bad. if you have a alarm then that might be the cause of it. you might have a ignition kill on the alarm and it probably took a ****, good luck.
btw: sparks might fly, wear eye protection
Old Feb 15, 2005 | 05:29 AM
TurboBumblBee's Avatar
Default Re: Starter help???please (emo-ejcoupe1.6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emo-ejcoupe1.6 &raquo;</TD></TR><TR><TD CLASS="quote">there's a trick to seeing if its your starter.
#1 ignition wire
btw: sparks might fly, wear eye protection </TD></TR></TABLE>
Old Feb 19, 2005 | 11:30 AM
lol its my starter thnx for helping
Mars401
Nov 14, 2016 02:16 PM
twentyhurtz
Dec 14, 2009 12:28 PM
bayoufrogg
Oct 24, 2006 08:18 PM
rex_racer728
24
Feb 3, 2006 10:57 AM
Baron55
Sep 25, 2005 04:19 PM
