tranny inspection
Old Feb 13, 2005 | 09:12 PM
racerpat94's Avatar
Default tranny inspection
is there any way that i can check the syncros, etc. on a d-series transmission <U>without</U> installing it?
Old Feb 13, 2005 | 10:47 PM
L8apex's Avatar
Default Re: tranny inspection (racerpat94)
Yeah you can take the trans apart. Seriously though, there's no way to check the synchro condition of a trans unless you can spin the input shaft fast enough. You can manually shift the transmission out of the car but at zero rpm, it won't tell you a thing about how it shifts at speed.
Old Feb 28, 2005 | 03:39 PM
racerpat94's Avatar
i know this is an old thread, but i have actually taken the time to bust apart the EX tranny to check the internals. there arent any metal shavings anywhere, except a very small amount by the magnet in the bottom. all bearing seem to roll smooth, and i cannot see any obvious damage other than a very slight groove through the center of the teeth on all of the gears. is this normal? any info is appreciated.
Old Mar 1, 2005 | 01:49 AM
L8apex's Avatar
Default Re: (racerpat94)
The groove or notch along all the teethe are normal. Have a look at the synchro rings.They're the smaller gold rings that accompany each gear. Make sure the teeth aren't too rounded (a sign that it has been shifted hard) and that no teeth are broken off. The main gears should have minimal wear since they're in constant mesh. It's the synchro rings that take the beating.
Old Mar 1, 2005 | 08:03 AM
Katman's Avatar
yeah you can actually....if your tranny grinds when you shift into gear...tall tale sign your syncros (for the respective gear that grinds) is going sour..
Old Mar 1, 2005 | 11:07 AM
racerpat94's Avatar
all of the syncros look ok to me. they all have the same shape, but they arent square. does anyone haave a pic of what they should look like?
doodooheadfart
Mar 16, 2007 11:50 PM
Circuit Star-29
Mar 6, 2006 09:03 PM
5thGhB
Aug 7, 2003 07:30 PM
pg_thao
Apr 12, 2003 06:14 AM
Allstar
Sep 13, 2002 08:46 AM
