how can you tell what motor?
Old Feb 13, 2005 | 02:23 PM
maxheat's Avatar
Default how can you tell what motor?
how can you tell what motor you have if its DOHC VTEC and the block's label has been scratched off? I just bought a GSR swap and the block says B1 with the rest scratched out but the head says P72...
i know its a gsr head but what about the block? is there any other ways of finding out besides taking the head off?
Old Feb 13, 2005 | 02:24 PM
ABK's Avatar
ABK
Default Re: how can you tell what motor? (maxheat)
LS
you bought an LS vtec (better hope it's not fucked up)
Old Feb 13, 2005 | 02:25 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: how can you tell what motor? (ABK)
yep, if it was a GSR block it would say C1, B1 indicates an LS block.
Old Feb 13, 2005 | 02:34 PM
PLAN:B's Avatar
I think they mean it says B1xxx (8C1 is missing)
Please clarify
Old Feb 13, 2005 | 02:39 PM
SOHCD16y8's Avatar
you can always pull the oil pan and see how the bottom is, oil squirters equal gsr
Old Feb 13, 2005 | 02:40 PM
ABK's Avatar
ABK
Default Re: how can you tell what motor? (PLANBmotorsports)
oh yeah that could make sense too.
Old Feb 13, 2005 | 02:44 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">you can always pull the oil pan and see how the bottom is, oil squirters equal gsr</TD></TR></TABLE>
Also the GSR block has a lot more external block ribbing (structural reinforcement) vs the LS block.
Old Feb 13, 2005 | 03:27 PM
areyouasian's Avatar
you should make sure the motor's not stolen and the numbers were scratched off b/c of that before worrying about it being a gsr or not
Old Feb 13, 2005 | 03:33 PM
JDMisGOOD's Avatar
Default Re: how can you tell what motor? (areyouasian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by areyouasian &raquo;</TD></TR><TR><TD CLASS="quote">you should make sure the motor's not stolen and the numbers were scratched off b/c of that before worrying about it being a gsr or not</TD></TR></TABLE>
not much you can do now that the numbers are ground off... he already bought it and would only be screwing himself by telling authorities...and just because the numbers are ground off doesn't mean its hot... altough there is a good chance it is...either way you are probably stuck with it
Old Feb 13, 2005 | 03:34 PM
Craven Moorehead's Avatar
sounds like someone got screwed
Old Feb 13, 2005 | 03:49 PM
ABK's Avatar
ABK
Default Re: (Craven Moorehead)
people choose to scrub off numbers to hide what's really underneath the hood. Sometimes you can fool people pretty good.
Old Feb 13, 2005 | 03:59 PM
JDMisGOOD's Avatar
Default Re: (ABK)
i have seen plenty at the race track with nice CNC machined surfaces where the numbers were...
Old Feb 13, 2005 | 04:38 PM
HATCHingMN's Avatar
drop it like it's hot
Old Feb 13, 2005 | 04:49 PM
maxheat's Avatar
well when you look at it in certain angles it looks like B17... which is a older 93' gsr so i guess id have to check if it has oil squirters
Old Feb 13, 2005 | 05:16 PM
SOHCD16y8's Avatar
if you pull the head youll know for sure
Justlearning95
Sep 21, 2016 07:09 AM
92integraVTECgsr
10
Feb 12, 2006 05:52 AM
TypeRobert
Oct 5, 2005 06:13 AM
1quickhatch
46
Feb 1, 2005 11:40 PM
baphomet
Sep 12, 2003 06:35 AM
