how can you tell what motor?
how can you tell what motor you have if its DOHC VTEC and the block's label has been scratched off? I just bought a GSR swap and the block says B1 with the rest scratched out but the head says P72...
i know its a gsr head but what about the block? is there any other ways of finding out besides taking the head off?
All Motor Mentor
1 Post
Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">you can always pull the oil pan and see how the bottom is, oil squirters equal gsr</TD></TR></TABLE>
Also the GSR block has a lot more external block ribbing (structural reinforcement) vs the LS block.
Re: how can you tell what motor? (maxheat)
you should make sure the motor's not stolen and the numbers were scratched off b/c of that before worrying about it being a gsr or not
Re: how can you tell what motor? (areyouasian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by areyouasian »</TD></TR><TR><TD CLASS="quote">you should make sure the motor's not stolen and the numbers were scratched off b/c of that before worrying about it being a gsr or not</TD></TR></TABLE>
not much you can do now that the numbers are ground off... he already bought it and would only be screwing himself by telling authorities...and just because the numbers are ground off doesn't mean its hot... altough there is a good chance it is...either way you are probably stuck with it
well when you look at it in certain angles it looks like B17... which is a older 93' gsr so i guess id have to check if it has oil squirters
Justlearning95
09-21-2016 07:09 AM
92integraVTECgsr
10
02-12-2006 05:52 AM
1quickhatch
46
02-01-2005 11:40 PM
