Bleeder valve piercing header..
Old Feb 13, 2005 | 11:42 AM
athoughts's Avatar
Default Bleeder valve piercing header..
Does anyone have a problem with their slave clinder rubbing up on thier header???
00' b16a2 / 93 coupe
Old Feb 13, 2005 | 11:47 AM
BigZ88's Avatar
Default Re: Bleeder valve piercing header.. (athoughts)
thats the first i've seen of that, what type of header are you running?
Old Feb 13, 2005 | 11:53 AM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Bleeder valve piercing header.. (BigZ88)
That **** is ****** wierd, hope you didn't spend too much on the header cause it looks fucked.
Old Feb 13, 2005 | 11:57 AM
Lmgrcivic's Avatar
Default Re: Bleeder valve piercing header.. (HondaFanatic708)
get a smaller valve the part in between the tip and the slave cylinder
what type of fan do you have on there
Old Feb 13, 2005 | 12:02 PM
Jaesung's Avatar
me too.
Old Feb 13, 2005 | 12:03 PM
PyroProblem's Avatar
Default Re: Bleeder valve piercing header.. (Lmgrcivic)
try running a thicker exhaust gasket or maybe 2 of them...Id say the header wasnt manufactured properly...get a different one or try the gasket trick...
What header is that?
Old Feb 13, 2005 | 12:09 PM
athoughts's Avatar
Default Re: Bleeder valve piercing header.. (PyroProblem)
its just a DC rip off, i had bought both, and the DC fit the same way, so i just went with the cheaper one..
you think more gaskets would give it a little clearance?
Old Feb 13, 2005 | 12:40 PM
athoughts's Avatar
well its good to go, i just cut the tip off of it with a hack saw :D
Old Feb 13, 2005 | 12:51 PM
Lmgrcivic's Avatar
what radiator fan you have on there
Old Feb 13, 2005 | 01:07 PM
athoughts's Avatar
FAL fan
BigZ88's Avatar
hope you dont ever have to bleed your clutch
its weird that the dc you supposedly tried fit like that when nobody yet has seen that happen before......weird
Old Feb 13, 2005 | 02:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">FAL fan </TD></TR></TABLE> That was gonna be my guess, you like that lo-profile FAL?
Old Feb 13, 2005 | 02:52 PM
athoughts's Avatar
ill put a rag over it when i have to bleed my clutch
Old Feb 13, 2005 | 02:58 PM
SOHCD16y8's Avatar
what slave cylinder you running? could be the problem
Old Feb 13, 2005 | 04:15 PM
BigZ88's Avatar
good solution you should put a tube on and down into a container with fluid in it.....to help the process and not allow air back into the system....
Old Feb 13, 2005 | 10:15 PM
.1type.'s Avatar
that is crazy. what header is that?
Old Feb 13, 2005 | 10:35 PM
athoughts's Avatar
Default Re: Bleeder valve piercing header.. (1type)
try reading some of the reply's...
its some cheap dc rip off header
Old Feb 13, 2005 | 11:05 PM
MiX's Avatar
MiX
i can vouch and say i own a dc sport and alot of peeps prolly do, and im postive when i say i dont have that problem.
Old Feb 14, 2005 | 06:37 AM
Jago's Avatar
Thats the first time I've seen a splash gard cut to clear the header.
Old Feb 14, 2005 | 06:42 AM
BeerBaron105's Avatar
had the same prob with an ebay header, ended up snapping off the bleeder, it fit fine, but now im fucked if i want to bleed my clutch lol
Old Feb 14, 2005 | 06:49 AM
Farmer Brown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">well its good to go, i just cut the tip off of it with a hack saw :D </TD></TR></TABLE>
That would have been my solution.
Or dent the header a little OMFGz0rNO!! NOT A DENT!!
You dont really need that part of the bleeder unless you intend to attach a hose anyway.
Old Feb 14, 2005 | 07:53 AM
spoonek9's Avatar
Default Re: Bleeder valve piercing header.. (Jago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago &raquo;</TD></TR><TR><TD CLASS="quote">Thats the first time I've seen a splash gard cut to clear the header.</TD></TR></TABLE>
I had to cut the splash shield on my EK to fit my ITR 4-1 on, but i wouldn't cut my bleeder valve off just to fit some cheap header on.
Old Feb 14, 2005 | 12:31 PM
athoughts's Avatar
Default Re: Bleeder valve piercing header.. (spoonek9)
I<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djaric &raquo;</TD></TR><TR><TD CLASS="quote">That would have been my solution.
You dont really need that part of the bleeder unless you intend to attach a hose anyway.</TD></TR></TABLE>
yeah when i bleed my clutch im just going to have to use a bigger hose..
and it doesnt matter if its a little dent, it was heating up the oil and my car was smoking..
"Thats the first time I've seen a splash gard cut to clear the header."
- what 4-1 header can fit without cutting that thing? or you just let it burn through?
Old Feb 14, 2005 | 02:49 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
thats just wierd
Old Feb 14, 2005 | 02:57 PM
Frozen E's Avatar
H-T White Ops
this will fix it for you
Called a 90 degree street elbow. Can be found at any decent hardware store.
96 EX
Jul 7, 2009 02:32 PM
dx_rex
Jan 9, 2009 07:24 AM
1994PreludeSi
Sep 12, 2007 09:08 PM
ImporttRacerr555
Nov 25, 2003 02:13 PM
