Bleeder valve piercing header..
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: Bleeder valve piercing header.. (BigZ88)
That **** is ****** wierd, hope you didn't spend too much on the header cause it looks fucked.
Re: Bleeder valve piercing header.. (HondaFanatic708)
get a smaller valve the part in between the tip and the slave cylinder
what type of fan do you have on there
Re: Bleeder valve piercing header.. (Lmgrcivic)
try running a thicker exhaust gasket or maybe 2 of them...Id say the header wasnt manufactured properly...get a different one or try the gasket trick...
What header is that?
Re: Bleeder valve piercing header.. (PyroProblem)
its just a DC rip off, i had bought both, and the DC fit the same way, so i just went with the cheaper one..
you think more gaskets would give it a little clearance?
Re: Bleeder valve piercing header.. (athoughts)
hope you dont ever have to bleed your clutch
its weird that the dc you supposedly tried fit like that when nobody yet has seen that happen before......weird
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts »</TD></TR><TR><TD CLASS="quote">FAL fan </TD></TR></TABLE> That was gonna be my guess, you like that lo-profile FAL?
good solution you should put a tube on and down into a container with fluid in it.....to help the process and not allow air back into the system....
i can vouch and say i own a dc sport and alot of peeps prolly do, and im postive when i say i dont have that problem.
Does anyone have a problem with their slave clinder rubbing up on thier header???
00' b16a2 / 93 coupe
Thats the first time I've seen a splash gard cut to clear the header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts »</TD></TR><TR><TD CLASS="quote">well its good to go, i just cut the tip off of it with a hack saw :D </TD></TR></TABLE>
That would have been my solution.
Or dent the header a little OMFGz0rNO!! NOT A DENT!!
You dont really need that part of the bleeder unless you intend to attach a hose anyway.
Re: Bleeder valve piercing header.. (Jago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago »</TD></TR><TR><TD CLASS="quote">Thats the first time I've seen a splash gard cut to clear the header.</TD></TR></TABLE>
I had to cut the splash shield on my EK to fit my ITR 4-1 on, but i wouldn't cut my bleeder valve off just to fit some cheap header on.
Re: Bleeder valve piercing header.. (spoonek9)
I<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djaric »</TD></TR><TR><TD CLASS="quote">That would have been my solution.
You dont really need that part of the bleeder unless you intend to attach a hose anyway.</TD></TR></TABLE>
yeah when i bleed my clutch im just going to have to use a bigger hose..
and it doesnt matter if its a little dent, it was heating up the oil and my car was smoking..
"Thats the first time I've seen a splash gard cut to clear the header."
- what 4-1 header can fit without cutting that thing? or you just let it burn through?
