Small problem with new DA exhaust!!
Old Feb 13, 2005 | 06:55 AM
iwhichisme's Avatar
Default Small problem with new DA exhaust!!
Just looking for some help in the DA department. I have a 90 rs that i recently swapped a b16a into. The problem is when i bought the car, it was basically a shell, so i had to pretty much source out everything i needed for it. I just recently bought an exhaust for it, but after installing it. I noticed that there is like a 5 or 6 inch gap between the cat and the header. ive heard of people having these types of problems with the second gen teg, but i dont remeber the solution to this problem. Is it the cat i have to switch out? or is the exahaust wrong for it?, which i doubt. The cat that is on there came from a 91 teg, but it seems like it needs to be much longer to work with the swap. BTW the header is the stock b16a (which is the 1st gen) manifold that came on the engine. Do i need to swap that out? Is the american b16a header longer?
any help is greatly appreciated.
tia,
chaz
Old Feb 13, 2005 | 09:37 AM
iwhichisme's Avatar
Default Re: Small problem with new DA exhaust!! (iwhichisme)
come on!! someone has got to know something. Im thinking the jdm b16a header is just too short and that i would need a usdm b-series header. Can someone quote me on this?
Old Feb 13, 2005 | 11:07 AM
J's 94 Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme &raquo;</TD></TR><TR><TD CLASS="quote">come on!! someone has got to know something. Im thinking the jdm b16a header is just too short and that i would need a usdm b-series header. Can someone quote me on this?</TD></TR></TABLE>
Try gettin spacers to fill in between the spaces. I know some muffler shops or some parts shop will sell them. What i would do is just have a muffler shop cut off the flange on the cat and have them weld in the extra space needed in between the flange and the cat.
Old Feb 14, 2005 | 11:19 AM
iwhichisme's Avatar
Default Re: Small problem with new DA exhaust!! (J's 94 Accord)
not a bad idea, ill have to look into that. Any other suggestions?
Old Feb 14, 2005 | 11:37 AM
purplegsr's Avatar
I don't know why you have a 6 inch space - what cat, header and exhaust are you using? If you have a 90-91 header, cat, and exhaust then the space shouldn't be that big even with the b16. In order to use a 90-91 exhaust on a 92-93 Integra, you usually need this extension that was sold with most catback exhaust kits at the time, but I am not sure how long it was.
The easiest thing, like mentioned before, is to have a little extension pipe made for you with flanges on either side - should cost around $50 or less.
Old Feb 14, 2005 | 11:58 AM
aznballer's Avatar
what the thing is the exhaust manifold of a 91-91 is longer than a 92-93 and. i kno bcuz i have both and sum exhaust companies supply a spacer for ur exhaust, when i purchased my greddy it came wit ha spacer but i dndt need it on my 91
Old Feb 14, 2005 | 06:46 PM
strikeback03's Avatar
the header, cat, and mid-pipe are all different lengths between 90-91 and 92-93. I know the b-pipe is longer for 92-93, the header is shorter, and I think the cat is longer. as mentioned, you can either try to buy all matching parts, or just have a muffler shop make you a spacer to take up the gap.
Old Feb 14, 2005 | 11:03 PM
silenttones's Avatar
haha i have the same problem i just installed the xsi (still not running) in the works of wiring it in my 90 Da. but there is a gap....i was just goin to get the jdm length test pipe from omnipower, it can actually extend too. yes, there wont be a cat. if your in cali, then id go to a muffler shop and get a cheap xtension - shouldnt be much at all.
Old Feb 14, 2005 | 11:07 PM
nub.96ek's Avatar
Default Re: Small problem with new DA exhaust!! (silenttones)
I had the same problem w/ my DA.
I put in a b16, 00 Si 1pc. header, a highflow cat for a 92 DA, stainless b-pipe and spoon rear sec. I just got a muffler shop to "fill" the gap and all was well. Find a good shop that won't do a crappy cut and paste and u should be fine.
Old Feb 15, 2005 | 07:41 PM
emissionsux's Avatar
I've seen that problem before also....do you have the stock header laying around or a 92? When I used my stock header on my swap, everything bolted up fine.
Old Feb 16, 2005 | 01:59 AM
Default Re: Small problem with new DA exhaust!! (emissionsux)
u can use ur stock header from the ls, which should fit but 4-1. the b16 comes w/ a 4-2-1.
Old Feb 20, 2005 | 12:38 PM
iwhichisme's Avatar
I appreciate everyones replies, i look into it it and found that most of you guys are right, and there are differences in the lengths in b-pipe, cat, etc for the 90-91 and 92-93. Ive decided to just take off the cat, and have it extended, rather than sourcing another header. BTW if i were to decide to go with a aftermarket header, would i have to change the cat again? or could i just find one for a 90-91 teg? What im asking is, is there a difference between the aftermarket headers on the 90-91 tegs and the 92-93?
tia,
chaz
Old Feb 20, 2005 | 06:16 PM
purplegsr's Avatar
Yes, the 90-91 integra header has the o2 on one of the primaries, while the 92-93 has the o2 bung after the merge collector, right before the cat.
Old Feb 22, 2005 | 08:50 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: Small problem with new DA exhaust!! (purplegsr (Exospeed))
well i put a B16a into my 93 DA, i had only about a 1/4 difffernce, and thats normal, 6 inches and u must be midly retarded with down syndrome. Go to an exhaust place!
Old Feb 22, 2005 | 08:54 PM
jizno's Avatar
I ran into the same problem when putting an RS*r catback on my 92 da.
All i did was just create a test pipe, use a piece of flex pipe and and old resinator, does the trick with some welding
wxman94ej1
12
Jul 8, 2014 05:25 AM
riddlinkid1986
Northwest (Sales)
Apr 9, 2008 11:32 PM
sohctodohc
Feb 8, 2007 04:17 PM
Brasspremier
May 3, 2003 04:06 PM
pelotudo
Jan 15, 2002 07:37 PM
