Help type R is over heating
Old Jan 17, 2002 | 07:59 AM
ITR079's Avatar
Default Help type R is over heating
my car is over heating. i replaced the thermo, coolent, radiator cap, set the timing back to stock. im clue less now. it happened after i put in my cam gears.
it over only over heats after i race someone. the coolent level in the resivor tank gets past the max but when the car cools down the resivor tank is still full. the coolent system isnt leaking anywhere.the lines to the resivor tank arnt clogged so now im in desprate need of some advice.
Old Jan 17, 2002 | 08:08 AM
Xian's Avatar
Default Re: Help type R is over heating (ITR079)
did yo properly bleed out any air bubbles in the coolant lines? maybe there's a bubble stuck in your waterpump causing it not to circulate the coolant properly?
BTW, I see you're in Jax too
[Modified by Xian, 12:08 PM 1/17/2002]
Old Jan 17, 2002 | 08:15 AM
yoshi234's Avatar
I shoot brides
Default Re: Help type R is over heating (Xian)
yup, most likely air bubbles
Old Jan 17, 2002 | 08:22 AM
ITR079's Avatar
Default Re: Help type R is over heating (yoshi234)
how would i properly go about getting out the air bubbles ?
Old Jan 17, 2002 | 08:25 AM
Xian's Avatar
should be a bleed screw just off of the engine up top where the hose goes from the engine to the radiator. Make sure you don't do it when the coolant is hot...
You going to the 1st autoX of the season on 2-16/17?
Old Jan 17, 2002 | 08:42 AM
ITR079's Avatar
I havent planned on oing to the auto -x havent been to one in like 2 years is it at whitehouse?
Old Jan 17, 2002 | 11:07 AM
sgT's Avatar
sgT
you guys have bleeder screws?
I have yet to see an ITR with one.
Old Jan 17, 2002 | 11:46 AM
typer_801's Avatar
Default Re: Help type R is over heating (sgT)
My ITR has muffler bearing too
Old Jan 17, 2002 | 11:49 AM
sgT's Avatar
sgT
Default Re: Help type R is over heating (typer_801)
damn. i got jipped. i didnt get one of those.
Old Jan 17, 2002 | 12:14 PM
Mike K's Avatar
steve, just use a b17a coolant neck if you want a bleeder.
that's what i did.
Old Jan 17, 2002 | 12:21 PM
sgT's Avatar
sgT
Default Re: Help type R is over heating (Mike K)
nah, i dont want a bleeder(why does saying that remind me of "something about mary"?)
I want a muffler bearing!
Old Jan 17, 2002 | 12:24 PM
Xian's Avatar
Sorry... flashbacks of my old CRX with a ZC in it.
Old Jan 17, 2002 | 12:28 PM
Xian's Avatar
check out the local website: http://www.buccaneersolo.org
no word on where it will be yet... just that it will be It's going to be a 2 day event. I'm going to try and be there for both days but I'll at least make Sun. Going to eb moving to CSP or SM this year... gotta size up the competition
Old Jan 17, 2002 | 12:47 PM
AssPenny's Avatar
how about taking off the top radiator hose and putting a garden hose in there and put some pressure to it. That should force any air bubbles out of the pump.
Old Jan 17, 2002 | 01:50 PM
RagingAngel's Avatar
Default Re: Help type R is over heating (AssPenny)
Juss remove the rad cap when the coolant is cool enough....
then start the car to warm it up and when it starts bubbling squeeze the top and bottom rad hoses and you will see the bubbles magically appear....
Works for me.... and it does make a small mess.... seems to be the way Honda wants you to do it ......other than the squeezing...
Old Jan 17, 2002 | 02:06 PM
Sam's Avatar
Sam
Default Re: Help type R is over heating (RagingAngel)
I don't think we have bleeder screw for B18C right?
but my older 86 Civic has one on it!
Old Jan 17, 2002 | 05:30 PM
SuperTwinz's Avatar
i think its time for one of these:
Old Jan 17, 2002 | 06:03 PM
JSIR's Avatar
New User
almost certain that it is air pockets in the cooling system. It has happened to me a couple times after putting the head back onto the car, only happened when I pushed the car hard in higher rpms and heavy throttle. After I bled the system a couple times it went away. Follow the Honda procedure for bleeding the system, run the car a few minutes with rad cap removed until fan comes on a couple times. Stop engine and refill rad to bottom of rad neck, make sure over-flow tank is at proper level, then put cap on fully tightened on rad. You might have to do it a couple times to get all the air out.
J.
Thatfrogguy71
Honda Civic (2001 - 2005)
May 2, 2016 05:15 PM
Empyre JDM
May 17, 2010 10:18 PM
dhn
23
Jan 5, 2008 01:06 AM
blemar56
Nov 28, 2006 09:28 PM
intekragsr
Oct 28, 2002 05:25 PM
