camber kit?
Old Feb 12, 2005 | 10:01 PM
EJ8 GSR-T's Avatar
Default camber kit?
Anyone ever installed an obx camber kit on a 98 civic? How do you get the (ill call it the "A" arm) from the connector rod(for lack of a better name). Must you get a ball joint seperator, and compressor?
Old Feb 12, 2005 | 10:13 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: camber kit? (userdead626)
So are you asking how to get the balljoint from your stock upper control arm to the spindle off? If so, some taps from a decent sized hammer should break it loose after a couple of hits.
Old Feb 12, 2005 | 10:18 PM
EJ8 GSR-T's Avatar
Default Re: camber kit? (litterbox)
i beat on the damn thing for an hour, with vaious different objects and nothing, but if i get a joint spereator is it difficult to put back together?
Old Feb 12, 2005 | 10:21 PM
litterbox's Avatar
You might ruin the actual balljoint using a seperator. You shouldn't, but you might, and if you don't have a replacement that came with the obx kit, then you'll have to buy another one.
When I got my stock ones off originally, I put small jack between the upper control arm (a-arm) and the rotor and jacked slowly, and it popped right off. If that doesn't work, do that and hammer at it and it should come off. Be careful, because you don't want to damage those parts.
Just a suggestion.
Old Feb 15, 2005 | 04:40 PM
EJ8 GSR-T's Avatar
Anyone ever installed one like the one on the left? on a civic?
Old Feb 16, 2005 | 02:06 PM
EJ8 GSR-T's Avatar
bump
Old Feb 18, 2005 | 03:28 PM
EJ8 GSR-T's Avatar
noone?
Old Feb 18, 2005 | 05:20 PM
dohc notec's Avatar
no you do not need those. just take the nut off of the BJ then hit the knuckle with a hammer and it will come out. the separator just tears the boot. now by knuckle i mean the part that the BJ stud goes through. and as for getting them off of the control arm there is a snap ring on one side then just wack it with a hammer. it should come right out.
Old Feb 18, 2005 | 06:06 PM
Tim.'s Avatar
Default Re: camber kit? (dohc notec)
this is an eassy job. you need no special tools at all, i did this by myself in about an hour and a half. its all pretty easy to take apart.
russianswty
Mar 9, 2007 10:26 PM
AWDxBOOST
Sep 6, 2005 08:53 PM
turbotime
Apr 14, 2005 09:00 AM
