LS/Vtec Oil Feed Head Plug...
Old Feb 12, 2005 | 05:57 PM
pK1spooled's Avatar
Default LS/Vtec Oil Feed Head Plug...
Hi, got a little problem. Trying to do Ls vtec with my GSR head, and the plug near the distibutor for the oil line is stuck. Its an 8mm hex, and i have hex keys as well as sockets, and I put alot of leverage on it and it began to chew up the plug. I can still fit a hex key in it so its not that bad, but what the hell do I do to get this thing out? The head was recently cleaned and refinshed by a shop, does this have anything to do with it? Can i apply heat to it with a torch? i know its aluminum and I dont wanna screw it up... I can try an impact gun on low setting, by again im afraid to without asking first...
any help out there please!
Old Feb 12, 2005 | 06:07 PM
mmuller's Avatar
Mad Scientist
Default Re: LS/Vtec Oil Feed Head Plug... (pK1spooled)
those suckers are on there pretty tight; use a torch to heat it up and impact it out
Old Feb 12, 2005 | 08:26 PM
pK1spooled's Avatar
Default Re: LS/Vtec Oil Feed Head Plug... (mmuller)
im worried about the aluminum... how much heat? anyone else got good ideas?
Old Feb 13, 2005 | 12:14 AM
vtec94civic's Avatar
yeah what he said said just heat it up a little and it will come loose
Old Feb 13, 2005 | 04:23 AM
SlowReaction's Avatar
Default Re: (vtec94civic)
I used a 3/8" socket that has the 8mm allen.
bambbrose
May 19, 2005 09:48 AM
SLow-Side
Nov 21, 2004 03:14 PM
turboITR#704
Mar 7, 2004 01:39 PM
VXpride
Jun 13, 2002 05:05 PM
