stock b16 turbo
Old Feb 12, 2005 | 02:14 PM
aldong's Avatar
Default stock b16 turbo
about how many pounds would be good on a stock 99si motor with 60xxx miles with t3t4 without blowing it?
Old Feb 12, 2005 | 02:19 PM
sohcmasta's Avatar
with an fmu, maybe 7psi. with an afc hack tuned, maybe 9-10psi. with hondata maybe 12psi...
Old Feb 12, 2005 | 03:00 PM
Honda V-Tec's Avatar
Default Re: (sohcmasta)
blow a b16 out with 12 psi ~.^
Old Feb 12, 2005 | 03:03 PM
ZeRo AsSault's Avatar
To stay safe I'd run about 8psi stock, anything more without a good tune will be quite risky
Old Feb 12, 2005 | 03:21 PM
gobblebox59's Avatar
Default Re: (ZeRo AsSault)
make a manual boost controler for like $15 and just turn up or down the boost when you want to
Old Feb 12, 2005 | 09:02 PM
hOndafienD 04's Avatar
Default Re: (gobblebox59)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gobblebox59 &raquo;</TD></TR><TR><TD CLASS="quote">make a manual boost controler for like $15 and just turn up or down the boost when you want to </TD></TR></TABLE>
would you care to explain on how to make it?
also this will be running on 310cc injectors for now...it will not run on stock injectors, and we also will be using an fmu...thanx
Old Feb 12, 2005 | 09:10 PM
8krdline's Avatar
Default Re: (Honda V-Tec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda V-Tec &raquo;</TD></TR><TR><TD CLASS="quote">blow a b16 out with 12 psi ~.^ </TD></TR></TABLE>
i know someone running 12lbs on a stock b16 for over a year now
Old Feb 12, 2005 | 10:13 PM
Si Shane's Avatar
Default Re: (8krdline)
Bah, you cant run **** with what you've got. How much money do you have.
Old Feb 12, 2005 | 10:33 PM
blaster834's Avatar
average of about 8 psi i would say tuned properly
Old Feb 12, 2005 | 11:43 PM
civic_si-99's Avatar
Default Re: (Si Shane)
Old Feb 13, 2005 | 12:21 AM
aldong's Avatar
what should i do then
Old Feb 13, 2005 | 08:51 AM
Si Shane's Avatar
Default Re: (aldong)
How much money do you have?
Old Feb 13, 2005 | 08:52 AM
Si Shane's Avatar
do you even own a turbo kit allreayd? if not go read and stop posting.
If your another dreamer, just go wait. Go read. You dont need to post yet. Not untill you have a real problem. I got told the same ****, but look at me nwo, i can actually help kids like you!
if you do tell me how much ******* money you have an i'll help you buy the right ****.
Old Feb 13, 2005 | 09:53 AM
Blazin Civic's Avatar
DAMNIT! Psi is irrelevant! Power blows the motor not psi. Leaving out the detonation factor (if you aren't gonna tune it right don't waste your money on a turbo), the amount of power you are making will determine how many psi to run. Running 10psi on a 15G will be a lot different than running 10psi on a t60.
Old Feb 13, 2005 | 10:07 AM
Si Shane's Avatar
Default Re: (Blazin Civic)
dont swear, its not irrelivant. My tdo5 blowing 14 poiunds into a stock motor will blow it up before i hit 300whp. everfything matters, even the temperature outside.
Old Feb 13, 2005 | 11:23 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
remove your rev limiter and governor, run 37 lbs., rev to 11.5k RPM and get back to us.
Old Feb 13, 2005 | 11:30 AM
GTlvr82's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">dont swear, its not irrelivant. My tdo5 blowing 14 poiunds into a stock motor will blow it up before i hit 300whp. everfything matters, even the temperature outside. </TD></TR></TABLE>
no....YOU don't swear, and offer this kid advice and stop postwhoring. If you want to bitch at each other...do it somewhere else. help him or get out...simple.
EDIT: And if your gonna bitch at someone.....use proper grammar....or at least learn how to spell......4 words.....in your quote
Old Feb 13, 2005 | 03:35 PM
the turbo is inside the car already....dont be dicks.....he just wants to know what he can run safely untill he tunes...i hate h-t cuz every1 is an *******
Old Feb 13, 2005 | 03:37 PM
JDMisGOOD's Avatar
Default Re: (hOndafienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">the turbo is inside the car already....dont be dicks.....he just wants to know what he can run safely untill he tunes...i hate h-t cuz every1 is an *******
no more than 7-8psi with FMU...
Old Feb 13, 2005 | 03:56 PM
^^^thanx....thats what i needed a striaght foward anwser.....he is running an fmu and rc 310 injectors, he will switch to 440's and get it tuned shortly.
Old Feb 13, 2005 | 04:32 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">
no more than 7-8psi with FMU...</TD></TR></TABLE>
i agree.. after 7-8 PSI on the FMU, you run out of fuel.. theyre's only soo much pressure you can create at the rail.. after that, its going to go lean.
with a stand alone, you can easily go 10 PSI with larger injectors.. i speak with experiance, im 7 PSI on a 1.5 VX w/ 230K miles and stock 240 CC injectors.
AfEn808
26
Feb 7, 2023 10:50 AM
honda_mike
Oct 29, 2008 10:46 AM
JDMallTHEway
Oct 15, 2004 09:14 PM
slo_crx
Oct 6, 2004 08:31 AM
mrx
Jul 29, 2004 11:02 AM
