M21 vs. BC 3+
CAM SPECS --
*Rocket motorsports M21
11.6mm lift, 274 duration (intake) 11.6mm lift, 274 duration (exhaust)
vs.
*Buddy Club spec 3+
11.4mm lift, 296 duration (intake) 11.8mm lift, 290 duration (exhaust)
THE SETUP --
*B16A2; approximately 10.8:1cr
*Will be primarily for daily driving and occasional track outings.
Engine management:
-Dyno tuned most likely w/ Hondata S200
Intake:
-stock with Hondata gasket and K&N drop in filter
Head:
-Buddy Club cam gears
-Rocket's Gen 2 valve springs, titanium retainers and flat faced valves
-AEBS head studs
-3 angle valve job and new OEM timing belt
Block:
-bored/honed to 81.5 with OS p30 pistons and new OEM bearings
-ITR oil pump
Exhaust:
-T1R SS 4-2-1 header with 2.5" collector
-SS Straight pipe
-2.5" SS Kteller piping with 16" resonator and Magnaflow oval
I'm just curious to see others opinions.
Thanks,
-Mike
P.S. - if anyone has M21 dyno sheets, please post. I have not seen a single one and no luck searching.
Modified by SleepEMike at 7:10 PM 4/9/2005
vs.
*Buddy Club spec 3+
THE SETUP --
Engine management:
Intake:
Head:
-AEBS head studs
Block:
-ITR oil pump
Exhaust:
-SS Straight pipe
Thanks,
-Mike
the duration on bc3+ is like 295 or so but not 300
and we dyno did a bc3+ cam test on an all stock b16
stock 135whp
stock with bc3+ 145whp
stock with bc3+ and Intake cam gear +2
152whp
stock with bc3+and intake cam gear +2 and jdm itr (runing open header) 165whp
these r on a dyno jet
https://honda-tech.com/zerothread?id=1107932
stock 135whp
152whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed »</TD></TR><TR><TD CLASS="quote">the duration on bc3+ is like 295 or so but not 300
stock 135whp
152whp
good ****!
135whp stock to 165whp bc3+ + gears + tuning. 30whp....thats very good.
stock 135whp
152whp
good ****!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic »</TD></TR><TR><TD CLASS="quote">
good ****!
135whp stock to 165whp bc3+ + gears + tuning. 30whp....thats very good. </TD></TR></TABLE>
WASN T TUNED
ONLY CAM GEAR ADJUSTING
DIDN T ADJUST AIR FUEL OR TIMING YET
good ****!
WASN T TUNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepEMike »</TD></TR><TR><TD CLASS="quote">Hrmmm, how much more power can be squeezed out by adjusting the air fuel and cam timing?
from the looks of air fuel
not much more peak maybe about 3-5 with timing adjustment
but mid range will be a very big gain!
</TD></TR></TABLE>from the looks of air fuel
From what I've seen B16's don't like much cam. Much more than CTR's and your spinning the bitch to 9.5k before the good power kicks in.
Look at Omni's 200whp B16. Peak power was at 9.2k rpms with a profile similiar to TODA' Cs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">From what I've seen B16's don't like much cam. Much more than CTR's and your spinning the bitch to 9.5k before the good power kicks in.
Look at Omni's 200whp B16. Peak power was at 9.2k rpms with a profile similiar to TODA' Cs.</TD></TR></TABLE>
thanks 4 the heads up
UPDATE:
I went with the stock injectors for now until the break in is finished for tuning and BC3+ because of the sufficient mid range in consideration of an already acquired T1R 4-2-1 header, prescribed compression ratio (CR) in correlation to the motor's approximately 10.8:1, smooth idle, advanced chill casted design technology, availability and affordability.
If I would of had a slightly higher CR and a 4-1 I would have definitely gone with Rocket's m22 cams. Only downside of the BC spec 3+ cam is the profile, the duration is a bit on the large side for a B16.
http://m24x.zeroforum.com/zero...age=2
Until the next update or my next post, cheers damsels and gents!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">Well we just got done dynoing a stock B16 with the smaller old spec m22's and they picked up 7-10whp throught over a big name brand
my STOCK BLOCK and unported Head b16 made 170whp with M22s. all i did was install omnipower valves, .10 mill, m22s and AEBS manifold.
baseline was 146whp
</TD></TR></TABLE>my STOCK BLOCK and unported Head b16 made 170whp with M22s. all i did was install omnipower valves, .10 mill, m22s and AEBS manifold.
baseline was 146whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD »</TD></TR><TR><TD CLASS="quote">
baseline was 146whp
how much compression do you pick up with a .10 mill? I want to run M22's but not sure what combination of things to up the compression...
baseline was 146whp
</TD></TR></TABLE>how much compression do you pick up with a .10 mill? I want to run M22's but not sure what combination of things to up the compression...
How much do you have to rev a B16 to make good power from M22? Since M22 has 12.1 lift the BC3+ seem better for a daily driver who doesnt want to spin a bearing?
How is the primary and secondary lobe between the two cams?
Nisif
47
Sep 21, 2010 08:29 PM
