Big Valve Head vs V2V
Old 04-06-2012, 06:58 PM
Moderator in Chief
Muckman's Avatar
Icon3 Big Valve Head vs V2V
I have a DART head with +1mm intake and +1mm exhaust valve. I decided to run the Skunk2 Tuner1 cam but have found I need 5 degrees of cam seperation to maintain .030" v2v @ .000" lash. That seems a little ridiculous! What do you guys do to run really aggressive cams with big valves? Does anyone have similar experience with dual oversized valves?
Here is my v2v table
Cams at 0/0 = .005" v2v
Old 04-07-2012, 01:27 AM
eDm cRxXx's Avatar
Default Re: Big Valve Head vs V2V
Did the cam gears line up properly when you put the cam belt on?
Maybe you should try and degree them on the engine to see where they end up.
Old 04-07-2012, 04:53 AM
koczeka's Avatar
It does not make any sense using 1mm oversize on both intake and exhaust resulting very limited camshaft selection and degree settings.
What you win with the big valves U loose with the small cams and restricted settings.
For a big power turbo setup your combination would work... not smart for NA.
BTW I like the chamber... show pics of the ports too!
Old 04-07-2012, 06:47 AM
Moderator in Chief
Muckman's Avatar
No I didnt degree the cams. I dont have any dial indicators.
Actually this is a turbo application. I posted in the all motor forum bc you guys have more experience with oversized valves. You can still run alot of lift with big valves just cant have alot of overlap.
As requested
Old 04-07-2012, 07:50 AM
EG1834's Avatar
I would think your best options are either sinking the valves or accepting the safe range of settings and seeing what it does. You may be surprised.
Old 04-07-2012, 11:09 AM
Moderator in Chief
Muckman's Avatar
You may be right. But I can't run the cams even close to 0/0 to compare.
What do you guys think about the .030" v2v safety margin plus the .000" valve lash safety margin? Is the double safety margin nessecary or are those two seperate requirements?
Im trying to understand where the .030" v2v came from. If the lash is at 0 thats the closest the valves will ever get, right? I would think any positive v2v clearance is enough in that situation. Has anybody run less than .030" v2v?
Old 04-07-2012, 11:30 AM
SP GARAGE's Avatar
Any reason why you went with +1 on the exh?
Old 04-07-2012, 01:43 PM
JDogg's Avatar
I have seen guys sink the exhaust valve in order to gain some clearance... but rarely does anyone use big exhaust valves
Old 04-07-2012, 01:53 PM
SP GARAGE's Avatar
Most head I've used we done os intake vales and stock exh valves works Great and still have great v2v
Old 04-07-2012, 02:02 PM
Fink29's Avatar
I also run a 34mm intake valve and stock exhaust. With the custom cams I got from Rocket my v2v @ 0,0 is 0.030
Old 04-07-2012, 03:06 PM
Moderator in Chief
Muckman's Avatar
How much can I sink the valve seats? Are there any negative effects of doing that?
Old 04-07-2012, 04:49 PM
97mm_EH3's Avatar
Unless you actually degree in the cams, your cam gear #'s mean nothing. Plus the centerlines for a turbo are different than NA on the same cams. Intake closing and EX opening numbers ( the two most important) are different for turbo/ NA motors. Plus you gain V-V and V-P with the proper valve lash, which is 10-11 intake and 13-14 thou when done correctly "I will let you figure that out".
Old 04-07-2012, 05:43 PM
hYbRid_Eg6's Avatar
What would the clearance be if you went +.5mm on the exhaust side, instead of the +1mm? Would you get the .030 clearance that you needed?
Old 04-08-2012, 02:43 PM
97mm_EH3's Avatar
That should increase the clearance by .010 thou.
Old 04-08-2012, 06:32 PM
Moderator in Chief
Muckman's Avatar
I found that +1mm of valve diameter was worth .025" v2v when comparing the same cam.
Old 04-09-2012, 07:21 AM
4piston's Avatar
The DART head was a pretty good head. That port doesn't look like the darts I have seen, but its been a long time. Put a new VJ on it for a stock size exh valve and put stock size exh valves in there.
Old 04-09-2012, 07:35 AM
GhostAccord's Avatar
If you want to run larger valves you should find yourself an engine with a better valve angle. My 2¢
Old 04-09-2012, 02:47 PM
97mm_EH3's Avatar
It should be .020, and the guy above me was talking .05mm or .010 cl. As the pro series cams from Skunk seem to want the EX. advanced, so when you actually degree them the V-V will be different, plus add the increased cl. when you adjust the valves, you do not even have a question yet, until you do it correctly to start with.
A battery powered drill, belt sander, and caliper will allow you to remove .05mm and you can radius the leading edge of the margin.
Old 04-09-2012, 05:28 PM
93supercoupe's Avatar
can you cut in smaller valves after youve already cut in +1mm?
Im in the same boat.
Old 04-10-2012, 04:02 AM
EG1834's Avatar
You might be able to, but it may hurt the performance of the valvejob. It depends on the size of the venturi (aka the throat). Many head porters like to open up the venturi to as much as 92% of the valve, so going to a smaller valve may not leave much room for the bottom cuts, or even the seat in worse case scenarios.
Old 04-11-2012, 07:05 AM
4piston's Avatar
It really just depends on the port and how the head guy set it all up. If it was my motor I'd put new seats in if needed and run the smaller exh valve. With the popular cams out there, I think the extra cfm you got there will not make more power than having some flexibility with moving the cam. Also, sinking the vj can eat up more cfm than you gained going to the bigger valve...so be careful with that.
We run stock size valves on B heads and our customers who opt for that seem to have more success than the guys that insist on me using a larger valve. That is on my port...I'm not speaking for anyone else. I have customers running 10s AM in street class cars on stock strokes and around 300hp and some running very low 11s in daily drivers AM...stock stroke, intake manifolds, basic small cams. It seems to work well on the bigger motors too, and it keeps it simple for guys that always seem to skip checking clearances HA HA.
Old 04-11-2012, 07:52 AM
hYbRid_Eg6's Avatar
Question? I kind of have the same thing, but I have +1mm intake and +.5mm exhaust, my question is after you get the clearances my cam card(Brain Crower 2 stage NA cam) tells me to set at 0/0 for best results then adjust while tuning. Now do I start the car at 0/0(.015) or do I go with my measurements?
Old 04-11-2012, 07:56 AM
4piston's Avatar
You need to degree the cams and not go off of suggested gear settings. Set the head up on the bench assembled with some test springs and rotate it over at various settings and measure your valve to valve. Map out where you can and can not go on a piece of paper and keep those notes with you when you go to the dyno.
Old 04-11-2012, 02:27 PM
spoolinvtec54's Avatar
4 pistion racing you talking about a stock stroke b series making 300 hp if so that's really good numbers.
Old 04-11-2012, 06:17 PM
hYbRid_Eg6's Avatar
I already have my measurements, what I'm asking is do I keep it 0/0 for the first initial start up with my base map so I can check for leaks or do I start with the cam gears adjusted already then check for leaks and then head to the dyno?
Quick Reply: Big Valve Head vs V2V
