Grinding Gears....
Old Feb 12, 2005 | 09:46 AM
LSEGHATCH's Avatar
Default Grinding Gears....
I am wondering how hard it is on the tranny when you accidenly grind a gear, not grind into a gear, but just grind one. I've noticed on eg dx hatch, that when going into second, it likes to grind sometimes. Mostly my fault because the clutch must not be pushed in all the way .. But how does this effect the tranny short term wise, say if you did it like 1x a month or so....
Old Feb 12, 2005 | 10:26 AM
primeredbeast's Avatar
Default Re: Grinding Gears.... (LSEGHATCH)
you could screw the syncro all up and not be able to even get into the gear
Old Feb 12, 2005 | 10:29 AM
LSEGHATCH's Avatar
Well I've only done it twice so, should the tranny still be ok?
Thanks
Old Feb 15, 2005 | 05:45 AM
TurboBumblBee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH &raquo;</TD></TR><TR><TD CLASS="quote">Well I've only done it twice so, should the tranny still be ok?
Thanks</TD></TR></TABLE>
yes it should be fine.. dont make it a habit of doing it tho
an2ny888
Aug 7, 2007 04:18 AM
wallawee
Jul 29, 2006 05:43 PM
civic16
May 1, 2006 02:29 PM
Bulldogg83
Apr 15, 2004 03:37 PM
SupaFly_Honda
Oct 8, 2003 06:55 PM
